Though off-topic, but continuation of stand-alone dump1090-fa installation
On Fedora 31, tried dump1090-fa’s lighttpd integration as below - FAILED
@obj
@wiedehopf
Any thoughts?
sudo dnf install lighttpd
sudo cp ~/dump1090-fa/debian/lighttpd/89-dump1090-fa.conf /etc/lighttpd/conf.d/89-dump1090-fa.conf
sudo chmod 666 /etc/lighttpd/lighttpd.conf
echo "server.modules += ( \"mod_alias\" )" >> /etc/lighttpd/lighttpd.conf
echo "include \"/etc/lighttpd/conf.d/89-dump1090-fa.conf\"" >> /etc/lighttpd/lighttpd.conf
sudo chmod 644 /etc/lighttpd/lighttpd.conf
sudo systemctl enable lighttpd
sudo reboot
lighttpd.conf (Last 2 lines at bottom are additions by me)
[abcd@fedora-31 ~]$ cat /etc/lighttpd/lighttpd.conf
## /etc/lighttpd/lighttpd.conf
## check /etc/lighttpd/conf.d/*.conf for the configuration of modules.
## Some Variable definition which will make chrooting easier.
## if you add a variable here. Add the corresponding variable in the
## chroot example aswell.
var.log_root = "/var/log/lighttpd"
var.server_root = "/var/www"
var.state_dir = "/var/run"
var.home_dir = "/var/lib/lighttpd"
var.conf_dir = "/etc/lighttpd"
## run the server chrooted.
## This requires root permissions during startup.
## If you run Chrooted set the the variables to directories relative to
## the chroot dir.
## example chroot configuration:
#var.log_root = "/logs"
#var.server_root = "/"
#var.state_dir = "/run"
#var.home_dir = "/lib/lighttpd"
#var.vhosts_dir = "/vhosts"
#var.conf_dir = "/etc"
#server.chroot = "/srv/www"
## Some additional variables to make the configuration easier
## Base directory for all virtual hosts
## used in:
## conf.d/evhost.conf
## conf.d/simple_vhost.conf
## vhosts.d/vhosts.template
var.vhosts_dir = server_root + "/vhosts"
## Cache for mod_compress
## used in:
## conf.d/compress.conf
var.cache_dir = "/var/cache/lighttpd"
## Base directory for sockets.
## used in:
## conf.d/fastcgi.conf
## conf.d/scgi.conf
var.socket_dir = state_dir + "/sockets"
## Load the modules.
include "modules.conf"
## Basic Configuration
server.port = 80
## Use IPv6?
server.use-ipv6 = "enable"
## bind to a specific IP
#server.bind = "localhost"
## Run as a different username/groupname.
server.username = "lighttpd"
server.groupname = "lighttpd"
## Enable lighttpd to serve requests on sockets received from systemd
## https://www.freedesktop.org/software/systemd/man/systemd.socket.html
#server.systemd-socket-activation = "enable"
## enable core files.
#server.core-files = "disable"
## Document root
server.document-root = server_root + "/lighttpd"
## The value for the "Server:" response field.
## It would be nice to keep it at "lighttpd".
#server.tag = "lighttpd"
## store a pid file
server.pid-file = state_dir + "/lighttpd.pid"
## Logging Options
## all logging options can be overwritten per vhost.
## Path to the error log file
server.errorlog = log_root + "/error.log"
## If you want to log to syslog you have to unset the
## server.errorlog setting and uncomment the next line.
#server.errorlog-use-syslog = "enable"
## Access log config
include "conf.d/access_log.conf"
## The debug options are moved into their own file.
## see conf.d/debug.conf for various options for request debugging.
include "conf.d/debug.conf"
## Tuning/Performance
## corresponding documentation:
## https://redmine.lighttpd.net/projects/lighttpd/wiki/Docs_Performance
## set the event-handler (read the performance section in the manual)
## possible options on linux are:
## select
## poll
## linux-sysepoll
## linux-sysepoll is recommended on kernel 2.6.
server.event-handler = "linux-sysepoll"
## The basic network interface for all platforms at the syscalls read()
## and write(). Every modern OS provides its own syscall to help network
## servers transfer files as fast as possible
## sendfile - is recommended for small files.
## writev - is recommended for sending many large files
server.network-backend = "sendfile"
## As lighttpd is a single-threaded server, its main resource limit is
## the number of file descriptors, which is set to 1024 by default (on
## most systems).
## If you are running a high-traffic site you might want to increase this
## limit by setting server.max-fds.
## Changing this setting requires root permissions on startup. see
## server.username/server.groupname.
## By default lighttpd would not change the operation system default.
## But setting it to 2048 is a better default for busy servers.
## With SELinux enabled, this is denied by default and needs to be allowed
## by running the following once : setsebool -P httpd_setrlimit on
#server.max-fds = 2048
## listen-backlog is the size of the listen() backlog queue requested when
## the lighttpd server ask the kernel to listen() on the provided network
## address. Clients attempting to connect() to the server enter the listen()
## backlog queue and wait for the lighttpd server to accept() the connection.
## The out-of-box default on many operating systems is 128 and is identified
## as SOMAXCONN. This can be tuned on many operating systems. (On Linux,
## cat /proc/sys/net/core/somaxconn) Requesting a size larger than operating
## system limit will be silently reduced to the limit by the operating system.
## When there are too many connection attempts waiting for the server to
## accept() new connections, the listen backlog queue fills and the kernel
## rejects additional connection attempts. This can be useful as an
## indication to an upstream load balancer that the server is busy, and
## possibly overloaded. In that case, configure a smaller limit for
## server.listen-backlog. On the other hand, configure a larger limit to be
## able to handle bursts of new connections, but only do so up to an amount
## that the server can keep up with responding in a reasonable amount of
## time. Otherwise, clients may abandon the connection attempts and the
## server will waste resources servicing abandoned connections.
## It is best to leave this setting at its default unless you have modelled
## your traffic and tested that changing this benefits your traffic patterns.
## Default: 1024
#server.listen-backlog = 128
## Stat() call caching.
## lighttpd can utilize FAM/Gamin to cache stat call.
## possible values are:
## disable, simple or fam.
server.stat-cache-engine = "simple"
## Fine tuning for the request handling
## max-connections == max-fds/2 (maybe /3)
## means the other file handles are used for fastcgi/files
server.max-connections = 1024
## How many seconds to keep a keep-alive connection open,
## until we consider it idle.
## Default: 5
#server.max-keep-alive-idle = 5
## How many keep-alive requests until closing the connection.
## Default: 16
#server.max-keep-alive-requests = 16
## Maximum size of a request in kilobytes.
## By default it is unlimited (0).
## Uploads to your server cant be larger than this value.
#server.max-request-size = 0
## Time to read from a socket before we consider it idle.
## Default: 60
#server.max-read-idle = 60
## Time to write to a socket before we consider it idle.
## Default: 360
#server.max-write-idle = 360
## Traffic Shaping
## see /usr/share/doc/lighttpd/traffic-shaping.txt
## Values are in kilobyte per second.
## Keep in mind that a limit below 32kB/s might actually limit the
## traffic to 32kB/s. This is caused by the size of the TCP send
## buffer.
## per server:
#server.kbytes-per-second = 128
## per connection:
#connection.kbytes-per-second = 32
## Filename/File handling
## files to check for if .../ is requested
## index-file.names = ( "index.php", "index.rb", "index.html",
## "index.htm", "default.htm" )
index-file.names += (
"index.xhtml", "index.html", "index.htm", "default.htm", "index.php"
## deny access the file-extensions
## ~ is for backupfiles from vi, emacs, joe, ...
## .inc is often used for code includes which should in general not be part
## of the document-root
url.access-deny = ( "~", ".inc" )
## disable range requests for pdf files
## workaround for a bug in the Acrobat Reader plugin.
$HTTP["url"] =~ "\.pdf$" {
server.range-requests = "disable"
## url handling modules (rewrite, redirect)
#url.rewrite = ( "^/$" => "/server-status" )
#url.redirect = ( "^/wishlist/(.+)" => "http://www.example.com/$1" )
## both rewrite/redirect support back reference to regex conditional using %n
#$HTTP["host"] =~ "^www\.(.*)" {
# url.redirect = ( "^/(.*)" => "http://%1/$1" )
## which extensions should not be handle via static-file transfer
## .php, .pl, .fcgi are most often handled by mod_fastcgi or mod_cgi
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi", ".scgi" )
## error-handler for all status 400-599
#server.error-handler = "/error-handler.html"
#server.error-handler = "/error-handler.php"
## error-handler for status 404
#server.error-handler-404 = "/error-handler.html"
#server.error-handler-404 = "/error-handler.php"
## Format: <errorfile-prefix><status-code>.html
## -> ..../status-404.html for 'File not found'
#server.errorfile-prefix = "/srv/www/htdocs/errors/status-"
## mimetype mapping
include "conf.d/mime.conf"
## directory listing configuration
include "conf.d/dirlisting.conf"
## Should lighttpd follow symlinks?
server.follow-symlink = "enable"
## force all filenames to be lowercase?
#server.force-lowercase-filenames = "disable"
## defaults to /var/tmp as we assume it is a local harddisk
server.upload-dirs = ( "/var/tmp" )
## SSL Support
## To enable SSL for the whole server you have to provide a valid
## certificate and have to enable the SSL engine.::
## ssl.engine = "enable"
## ssl.pemfile = "/path/to/server.pem"
## $SERVER["socket"] == "10.0.0.1:443" {
## ssl.pemfile = "/etc/ssl/private/www.example.com.pem"
## # Check your cipher list with: openssl ciphers -v '...'
## # (use single quotes as your shell won't like ! in double quotes)
## #ssl.cipher-list = "PROFILE=SYSTEM"
## # (recommended to accept only TLSv1.2 and TLSv1.3)
## #ssl.openssl.ssl-conf-cmd = ("Protocol" => "-ALL, TLSv1.2, TLSv1.3")
## server.name = "www.example.com"
## server.document-root = "/srv/www/vhosts/example.com/www/"
## If you have a .crt and a .key file, specify both ssl.pemfile and ssl.privkey,
## or cat them together into a single PEM file:
## $ cat /etc/ssl/private/lighttpd.key /etc/ssl/certs/lighttpd.crt \
## > /etc/ssl/private/lighttpd.pem
#ssl.pemfile = "/etc/ssl/private/lighttpd.pem"
# or
#ssl.privkey = "/etc/ssl/private/privkey.pem"
#ssl.pemfile = "/etc/ssl/private/cert.pem"
## optionally pass the CA certificate here.
#ssl.ca-file = ""
## and the CRL revocation list here.
#ssl.ca-crl-file = ""
## custom includes like vhosts.
#include "conf.d/config.conf"
#include "/etc/lighttpd/vhosts.d/*.conf"
server.modules += ( "mod_alias" )
include "/etc/lighttpd/conf.d/89-dump1090-fa.conf"
