Edit: Installed an active hub, hope that was the solution
Hi people,
I have upgraded from a simple Jetvision dongle to Pro Stick Plus, and the increased reception is amazing (up to 130 imperial miles with indoor antenna)
However it is new that two times now all planes vanished, 0Msg/s, while dump1090-fa was still up and running
I think my original 1st Gen Raspberry might be struggling with the load? Or is the USB not supllying enough power?
Thank you for your help on this, hoping to get it stable!
This is the log:
[2020-02-20 08:35 CET] mlat-client(8939): Server status: synchronized with 207 nearby receivers
[2020-02-20 08:35 CET] mlat-client(8939): Receiver: 252.9 msg/s received 47.3 msg/s processed (19%)
[2020-02-20 08:35 CET] mlat-client(8939): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.6kB/s UDP to server
[2020-02-20 08:35 CET] mlat-client(8939): Results: 22.7 positions/minute
[2020-02-20 08:35 CET] mlat-client(8939): Receiver status: connected
[2020-02-20 08:35 CET] mlat-client(8939): Aircraft: 6 of 11 Mode S, 22 of 24 ADS-B used
[2020-02-20 08:36 CET] 50171 msgs recv’d from dump1090-fa (669 in last 5m); 50037 msgs sent to FlightAware
[2020-02-20 08:41 CET] 51022 msgs recv’d from dump1090-fa (851 in last 5m); 50888 msgs sent to FlightAware
[2020-02-20 08:46 CET] 51039 msgs recv’d from dump1090-fa (17 in last 5m); 50905 msgs sent to FlightAware
[2020-02-20 08:50 CET] mlat-client(8939): Server status: not synchronized with any nearby receivers
[2020-02-20 08:50 CET] mlat-client(8939): Receiver: 85.6 msg/s received 18.8 msg/s processed (22%)
[2020-02-20 08:50 CET] mlat-client(8939): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
[2020-02-20 08:50 CET] mlat-client(8939): Results: 9.3 positions/minute
[2020-02-20 08:50 CET] mlat-client(8939): Receiver status: connected
[2020-02-20 08:50 CET] mlat-client(8939): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
[2020-02-20 08:51 CET] 51039 msgs recv’d from dump1090-fa (0 in last 5m); 50905 msgs sent to FlightAware
