Armbian Forky On Raspberry Pi Model 4
pi@armbian-forky:~$ sudo journalctl -u piaware -n 10
May 21 10:24:59 armbian-forky piaware[5277]: mlat-client(5309): Receiver status: connected
May 21 10:24:59 armbian-forky piaware[5277]: mlat-client(5309): Server status: synchronized with 274 nearby receivers
May 21 10:24:59 armbian-forky piaware[5277]: mlat-client(5309): Receiver: 507.4 msg/s received 61.5 msg/s processed (12%)
May 21 10:24:59 armbian-forky piaware[5277]: mlat-client(5309): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.7kB/s UDP to server
May 21 10:24:59 armbian-forky piaware[5277]: mlat-client(5309): Results: 1.3 positions/minute
May 21 10:24:59 armbian-forky piaware[5277]: mlat-client(5309): Aircraft: 10 of 13 Mode S, 25 of 30 ADS-B used
May 21 10:25:30 armbian-forky piaware[5277]: 12146 msgs recv'd from dump1090-fa (1358 in last 5m); 12146 msgs sent to FlightAware
May 21 10:25:30 armbian-forky piaware[5277]: 1 msgs recv'd from dump978-fa (0 in last 5m); 1 msgs sent to FlightAware
May 21 10:30:30 armbian-forky piaware[5277]: 13375 msgs recv'd from dump1090-fa (1229 in last 5m); 13375 msgs sent to FlightAware
May 21 10:30:30 armbian-forky piaware[5277]: 1 msgs recv'd from dump978-fa (0 in last 5m); 1 msgs sent to FlightAware
pi@armbian-forky:~$
Debian Forky on PC amd64 / x86_64
abcd@debian-14:~$ sudo journalctl -u piaware -n 12
May 21 11:30:00 debian-14 piaware[700]: 30870 msgs recv'd from dump1090-fa (1847 in last 5m); 30870 msgs sent to FlightAware
May 21 11:30:00 debian-14 piaware[700]: 189 msgs recv'd from dump978-fa (42 in last 5m); 189 msgs sent to FlightAware
May 21 11:34:34 debian-14 piaware[700]: mlat-client(727): Receiver status: connected
May 21 11:34:34 debian-14 piaware[700]: mlat-client(727): Server status: synchronized with 272 nearby receivers
May 21 11:34:34 debian-14 piaware[700]: mlat-client(727): Receiver: 482.2 msg/s received 88.9 msg/s processed (18%)
May 21 11:34:34 debian-14 piaware[700]: mlat-client(727): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.9kB/s UDP to server
May 21 11:34:34 debian-14 piaware[700]: mlat-client(727): Results: 11.3 positions/minute
May 21 11:34:34 debian-14 piaware[700]: mlat-client(727): Aircraft: 19 of 31 Mode S, 33 of 47 ADS-B used
May 21 11:35:00 debian-14 piaware[700]: 32599 msgs recv'd from dump1090-fa (1729 in last 5m); 32599 msgs sent to FlightAware
May 21 11:35:00 debian-14 piaware[700]: 211 msgs recv'd from dump978-fa (22 in last 5m); 211 msgs sent to FlightAware
May 21 11:40:00 debian-14 piaware[700]: 34362 msgs recv'd from dump1090-fa (1763 in last 5m); 34362 msgs sent to FlightAware
May 21 11:40:00 debian-14 piaware[700]: 216 msgs recv'd from dump978-fa (5 in last 5m); 216 msgs sent to FlightAware
abcd@debian-14:~$
Build and installed these packages from Flightaware source-code using following scripts:
NOTE: These scripts are very long and right-most part may not be visible directly. Please scroll right to see and copy these in Full
(1) PIAWARE
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-piaware.sh)"
(2) DUMP1090-FA
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-dump1090-fa.sh)"
(3) DUMP978-FA (For USA Only)
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-dump978-fa.sh)"
Pre-Built Packages of Piaware, dump1090-fa, and dump978-fa for Debian 14 (forky) are now available for following architectures at site linked below:
- 64-bit (arm64) for Raspberry Pi
- AMD64 x86_64 for Desktop / Laptop
https://github.com/abcd567a/debian14/blob/master/README.md
