Improving reception - NYC
Good morning everyone,
Looking to get any suggestions on increasing the reception for my site in NYC. It’s located in Ridgewood, Queens. Following config:
  • Flightaware orange recevier
  • Flightaware bandpass filter
  • Raspberry Pi 3B
  • Amazon (Tenmory) 5dBi 1090 antenna
  • Approx 50’ SMA to type N coax.
My receiver is this one: https://www.flightaware.com/adsb/stats/user/Solidjake#stats-241562
On good days my rank is in the mid 200’s and I’m looking to increase that a bit. The only things that come to mind is to get a Mini Circuits VBFZ-1065S bandpass filter and change the receiver to a better one (Nooelec v5 most likely). Another option is the filter/receiver and to get the DPD antenna.
I can’t raise the current antenna anymore and if I were to get the DPD I would use a 1 to 1 1/2" PVC pipe securely mounted to the roof access structure and get the base of the DPD antenna clear of the window line up top.
Thanks all.
Pic is a little older. At center of the pvc I secured it so the antenna is perfectly straight.
NORTH
SOUTH
SOUTH/SOUTHEAST
NORTHWEST
You could change the orange receiver for a airspy mini
You would need an LNA and filter like this one since the airpy mini needs some amplification to work well.
Combine that with some SMA couplers and you should see a good improvement on your performance.
I have a lot of hardware but the combo above is my best performing setup.
When I changed it over from the Prostick Plus (the blue one) to this setup I saw a 40 % increase in traffic positions and around 25-30 % increase in aircraft.
Mind you, these are not the cheapest components but they are worth every penny in squeezing the most out of your setup and location.
I installed the DPD antenna, replacing the FlightAware 1090MHz antenna. Installed in the exact same mounting location so height was increased by default due to overall longer length. I Understand you cant do that. A noticeable improvement. I dont have any stats to back that up but the improvement was obvious.
Thanks guys. I’ll have to see which one to start with since the cost is about equal. I might start with the Airspy and preamp to help clean up the reception by me. That site is smack in the middle of NYC so that should help the most to start.
Can you shorten the coaxial cable? Make it short enough to mount the SDR and RPi right next to the antenna? If you can’t do that, swapping the orange FlightAware stick for a blue one will already yield an improvement. If you’re willing to spend a bit more, I’d go with an Airspy Mini + LNA. The best setup: antenna + pigtail + cavity filter + LNA + Airspy Mini + RPi4. But it all depends on your willingness to invest both money and effort…
You could add a UAT 978 MHz receiver. Typically this will increase plane count a little – on the order of 1% or so.
Unfortunately I can’t. I have the coax running on the roof and going into the third floor apartment. There is still some extra coax but I have to leave it that way in case the living room config changes.
If I did the suggestion above would it be like this: antenna - coax - pre-amp - pigtail - airspy mini - pi?
For that I assume that in addition to the second antenna I would need to run another coax and use another stick for it go into the pi? In NYC it should pick up some UAT since there is GA traffic usually off to the east.
So, you would need to swap the “orange stick” for an Airspy Mini or an RTL-SDR v3/v4 with Bias-T. The correct setup would be: antenna > filter > LNA (powered via Bias-T) > long coaxial cable…
A long coaxial cable isn’t necessary for the setup I shared with you earlier. You can easily house your RPi, “orange stick,” FlightAware filter, and short coaxial cable or pigtail inside an IP67-rated enclosure (though passive or active ventilation might be required depending on the location or climate). Then, use a copper Cat6 or Cat5e UTP cable to power the equipment and transmit data to your indoor router or switch via PoE…
Yes, you will need that extra equipment to receive UAT.
For that investment, you can probably expect a few percentage points increase in plane count (GA).
I get about 1% additional but could improve on that with better antenna placement.
Meanwhile, looking at NYC’s high-speed traffic from my station (rank ~32k)… I feel like I’m driving a humble little Kei-truck compared to their F1 cars! But hey, my modest setup gets the job done. :delivery_truck::dashing_away: YUKIO
If you go for the LNA + Filter, mount that as close as possible to the antenna.
Edit: So what i cannot really guess from the pictures is the surface of the roof. Is that reflective to 1GHz? Looks to me like that.
Edit: Still a prime spot. Congrats!
You can tee off the SMA at the dongles. But that could introduce losses in the line. I use a separate antenna that also feeds ADSB Exchange and FlightRadar24 on a separate RPi. My UAS is less than 1% of total.
Thanks again all!
I will look at getting the Airspy mini with the preamp in a vented waterproof box. The box I will most likely have to mount on the side of the roof access where the old satellite dish is. I will get a separate SMA to type N coax that is around 6-8 feet or so and put one loop just under the connection at the antenna. The coax heading into the house I’ll look the extra somewhere on the roof prior to dropping down into the window area.
For the UAT I will probably get one more of those amazon antennas for now and just run straight up coax to the orange dongle on that pi receiver.
I will probably do this in September when I stop by my parents to visit.
Alright guys have an update.
Two weeks ago I changed out the lighter blue filter/orange receiver to the dark blue filter/receiver. Reception has gone up a bit and I noticed changes in the 200-250 and over 250NM report. They were somewhere along the lines of 6XXX/80 before to 7000-8000/100-180 after.
This morning I swapped out the 5dBi 16" Amazon antenna to the infamous DPD 1090 antenna and I have seen big spikes in reception. 200-250NM reports are now over 10K and the 250+ is sitting at 170 right now. I do not plan to invest anymore into this setup for 1090 specifically but I will add some coax and use the previous equipment for 978 probably in two weeks when I stay over at the apartment.
On the coverage graph prior to the DPD I have seen 5 to 6 quadrants where there were reports over 250NM. I will see in the next week or two if it stays the same or increases. I think it might stay the same due to high rises in the distance blocking the view to the antenna.
The 1000 position report is 107,090 and the 1100 is 116,096. The highest hits excluding today in those two hours have been 91,750 on Friday for the 1000 and 90,865 for the 1100 on the same day.
I will report back in a few days or tomorrow with today’s findings.
As of 1638Z
From personal experience, I can tell you to choose your PVC pipe carefully. If possible, avoid dark colors and make sure it’s not too thin.
In my previous installation, I noticed that the heat caused the pipe to sag quite a bit, and what we need from our antennas is for them to be perfectly straight.
In my case, I’ve now installed a 2.5m metal mast and a slightly shorter section of PVC pipe with the antenna attached. When I have time, I’ll add another 1.5m metal mast to shorten the PVC section even further.
June 2026:
:sweat_smile: :sweat_smile:
Haha thanks and of course! It’s white pvc. I don’t pick any dark colors. For my weather station i do have the metal mount which I might consider for this antenna or the one for 978
Be careful with that. In Europe, weather stations connect to the central unit at 868 MHz, extremely close to the 978 and 1090 MHz of ADS-B.
I don’t know what frequencies are authorized in other regions.
Just want to post an update for the DPD antenna. It’s definitely worth the money in my opinion. Reception went up a substantial amount. Position reports from 1.2-1.4 mil to 1.6-1.8. Also the 200-250 is much much higher and I’m getting more quadrants picking up 250+ reports.
I finally got the UAT antenna installed and setup. My brother did the coding since he does that all the time and it’s been a while for me. We ran the commands only one time and it worked right away. I took an Ikea board or whatever that my kids were not using and cut it so I could mount the equipment on it to make it look neat.
Don’t mind the slight bend on the smaller antenna. We have a nor’easter by us and it was windy as hell yesterday. My box with supplies almost flew off the roof!
