I have noticed the number of long range hits I get (400km+) seems to vary quite a bit day to day, some days I can get hundreds, other days maybe only 20 or so.
Does weather (mainly cloud cover) and/or atmospheric conditions impact this at all?
I know some of the higher frequency signals such as around the 2.4Ghz/Microwave can be impacted by moisture in the air, not so sure about 1090Mhz.
I believe that it does. I’ve noticed that when there are thunderstorms 600+ kilometers away, I will frequently receive signals from flights at otherwise-impossibly-low (11000 ft) altitudes in the 500-550km range. It’s almost as if the signal is bouncing off either the moisture in the air or the charged particles or something like that.
Similarly, I’ve noticed that when there are thunderstorms closer to home, along with high humidity levels, I’ll get more of the brief, long distance blips appearing. I’m open to other explanations, but weather can nditions seem to be a common factor.
