OK, modified version number in debian/changelog
and built package with version 0.6.0-3
, and installed, but Ubuntu repository is smart, refuses to accept bumped version as genuine:
ubuntu@ubuntu:~$ apt list --upgradable
Listing... Done
librtlsdr-dev/focal 0.6.0-3 arm64 [upgradable from: 0.6.0-3]
librtlsdr0/focal 0.6.0-3 arm64 [upgradable from: 0.6.0-3]
ubuntu@ubuntu:~/librtlsdr$ git diff
diff --git a/debian/changelog b/debian/changelog
index 24d97e2..83f63a3 100644
--- a/debian/changelog
+++ b/debian/changelog
@@ -1,4 +1,4 @@
-rtl-sdr (0.6git) unstable; urgency=medium
+rtl-sdr (0.6.0-3) unstable; urgency=medium
* New upstream release
diff --git a/src/librtlsdr.c b/src/librtlsdr.c
index 433ed5b..cdd2853 100644
--- a/src/librtlsdr.c
+++ b/src/librtlsdr.c
@@ -1748,7 +1748,7 @@ static int _rtlsdr_alloc_async_buffers(rtlsdr_dev_t *dev)
dev->xfer_buf = malloc(dev->xfer_buf_num * sizeof(unsigned char *));
memset(dev->xfer_buf, 0, dev->xfer_buf_num * sizeof(unsigned char *));
-#if defined (__linux__) && LIBUSB_API_VERSION >= 0x01000105
+#if defined (__linux__) && LIBUSB_API_VERSION >= 0x01000105 && 0
fprintf(stderr, "Allocating %d zero-copy buffers\n", dev->xfer_buf_num);
dev->use_zerocopy = 1;
ubuntu@ubuntu:~$ ls
dump1090-fa librtlsdr-dev_0.6.0-3_arm64.deb
dump1090-fa-dbgsym_3.8.1_arm64.ddeb librtlsdr0-dbgsym_0.6.0-3_arm64.ddeb
dump1090-fa_3.8.1_arm64.buildinfo librtlsdr0_0.6.0-3_arm64.deb
dump1090-fa_3.8.1_arm64.changes rtl-sdr-dbgsym_0.6.0-3_arm64.ddeb
dump1090-fa_3.8.1_arm64.deb rtl-sdr_0.6.0-3_arm64.buildinfo
dump1090_3.8.1_all.deb rtl-sdr_0.6.0-3_arm64.changes
librtlsdr rtl-sdr_0.6.0-3_arm64.deb
mikkyo
May 11, 2020, 8:24pm
45
I think if you just build master, this is already fixed.
There is a flag for zero copy,
–enable-zerocopy Enable usbfs zero-copy support (disabled by default)
which sets the macro ENABLE_ZEROCOPY=1 if set and doesn’t set it if not.
And that line you changed is now
#if defined(ENABLE_ZEROCOPY) && defined (linux ) && LIBUSB_API_VERSION >= 0x01000105
Thank you @mikkyo .
I now built it from master branch , and without any modification to file librtlsdr/src/librtlsdr.c
It works OK .
ubuntu-20.04-preinstalled-server-arm64+raspi.img
Installed on PI-4
Tried to build piaware, got stuck with python3-venv
ubuntu@ubuntu:~$ uname -a
Linux ubuntu 5.4.0-1008-raspi #8-Ubuntu SMP Wed Apr 8 11:13:06 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
make[2]: Leaving directory '/home/ubuntu/piaware_builder/package-bionic/dump1090'
pyvenv /home/ubuntu/piaware_builder/package-bionic/debian/venv --without-pip
make[1]: pyvenv: Command not found
make[1]: *** [debian/rules:61: setup_venv] Error 127
make[1]: Leaving directory '/home/ubuntu/piaware_builder/package-bionic'
make: *** [debian/rules:95: build] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
ubuntu@ubuntu:~$ apt policy python3-venv
python3-venv:
Installed: 3.8.2-0ubuntu2
Candidate: 3.8.2-0ubuntu2
Version table:
*** 3.8.2-0ubuntu2 500
500 http://ports.ubuntu.com/ubuntu-ports focal/universe arm64 Packages
100 /var/lib/dpkg/status
ubuntu@ubuntu:~$ pyvenv
Command 'pyvenv' not found, but can be installed with `python3-venv`
ubuntu-20.04-preinstalled-server-arm64+raspi.img, Installed on PI-4
Tried following hack.
$ sudo mv /usr/bin/pyvenv /usr/bin/pyvenv.orig
$ sudo ln -s /usr/share/bash-completion/completions/pyvenv /usr/bin/pyvenv
$ sudo chmod +x /usr/share/bash-completion/completions/pyvenv
$ ls -l /usr/bin/pyvenv
lrwxrwxrwx 1 root root 45 May 17 23:34 /usr/bin/pyvenv -> /usr/share/bash-completion/completions/pyvenv
After the above hack, the error “pyvenv: command not found” disappeared, but another error appeared: “/usr/bin/pyvenv: 23: complete: not found” .
ubuntu@ubuntu:~/piaware_builder/package-bionic$ sudo dpkg-buildpackage -b --no-sign
obj
May 18, 2020, 11:55am
49
Thanks to @obj with whose help & guidance I could finally succeed in installing dump1090-fa and piaware on Pi 4B running Ubuntu Server 20.04 arm64.
Thanks also to @postl and @mikkyo for their contribution.
I have created a separate thread for the finished procedure. This will enable users to get the complete and final howto without need to brows through lot of posts.
My AMD64 Ubuntu 19 offers the update to 20. I’m reluctant to do the upgrade…
Will this upgrade work now?
I did not try it, so not sure, but feel that if you have installed piaware and dump1090-fa according to fist post of this thread it should work even after upgrade.
If I find time this weekend (or may be next weekend), I will try upgrade of ver 19 amd64 to ver 20 amd64 on VM, and see what happens.
The installs were done a long time ago, per your other thread, and regular updates applied (with no ill effects).
Ok, upgraded from Ubuntu 19 to Ubuntu 20.
abcd@ubuntu19:~$ update-manager
Took about 2 hrs to complete
Piaware knocked-out by upgrade
abcd@ubuntu19:~$ sudo systemctl status piaware
● piaware.service
Loaded: masked (Reason: Unit piaware.service is masked.)
Active: inactive (dead)
dump1090-fa survived the upgrade
abcd@ubuntu19:~$ sudo systemctl status dump1090-fa
[sudo] password for abcd:
● dump1090-fa.service - dump1090 ADS-B receiver (FlightAware customization)
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled; vendor p>
Active: active (running) since Sat 2020-05-23 17:25:01 EDT; 2min 3s ago
Docs: https://flightaware.com/adsb/piaware/
Main PID: 2124 (dump1090-fa)
Tasks: 3 (limit: 4657)
Memory: 4.2M
CGroup: /system.slice/dump1090-fa.service
└─2124 /usr/bin/dump1090-fa --device-index 00001090 --gain -10 --p>
May 23 17:25:01 ubuntu19 systemd[1]: Started dump1090 ADS-B receiver (FlightAwa>
May 23 17:25:01 ubuntu19 dump1090-fa[2124]: Sat May 23 17:25:01 2020 EDT dump1>
May 23 17:25:02 ubuntu19 dump1090-fa[2124]: rtlsdr: using device #0: Generic RT>
May 23 17:25:02 ubuntu19 dump1090-fa[2124]: Detached kernel driver
May 23 17:25:03 ubuntu19 dump1090-fa[2124]: Found Rafael Micro R820T tuner
May 23 17:25:03 ubuntu19 dump1090-fa[2124]: rtlsdr: enabling tuner AGC
May 23 17:25:04 ubuntu19 dump1090-fa[2124]: Allocating 4 zero-copy buffers
lucpo1
May 24, 2020, 12:02pm
55
Hi,
I have issue with 2.2 point.
dpkg-shlibdeps: error: no dependency information found for /usr/local/lib/librtlsdr.so.0 (used by debian/dump1090-fa/usr/bin/dump1090-fa)
Hint: check if the library actually comes from a package.
dh_shlibdeps: dpkg-shlibdeps -Tdebian/dump1090-fa.substvars debian/dump1090-fa/usr/bin/view1090-fa debian/dump1090-fa/usr/bin/dump1090-fa returned exit code 255
dh_shlibdeps: Aborting due to earlier error
Ubuntu version
ubuntu@ubuntu18:~/dump1090-fa$ uname -a
Linux ubuntu18 5.3.0-53-generic #47~18.04.1-Ubuntu SMP Thu May 7 13:10:50 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Package version
ubuntu@ubuntu18:~/dump1090-fa$ apt list --installed | grep librtl
librtlsdr-dev/bionic,now 0.6.0-myriadrf1~bionic amd64 [zainstalowany]
librtlsdr0/bionic,now 0.6.0-myriadrf1~bionic amd64 [zainstalowany,automatycznie]
Your file is shown in folder /usr/local/lib/
My file is NOT in folder /usr/local/lib/
It is in folder /usr/lib/x86_64-linux-gnu/
It has dependency information (see NEEDED in output of 2nd command)
abcd@ubuntu18:~$ dpkg -S librtlsdr.so.0
librtlsdr0:amd64: /usr/lib/x86_64-linux-gnu/librtlsdr.so.0
librtlsdr0:amd64: /usr/lib/x86_64-linux-gnu/librtlsdr.so.0.5.3
abcd@ubuntu18:~$ readelf -d /usr/lib/x86_64-linux-gnu/librtlsdr.so.0 | grep NEEDED
0x0000000000000001 (NEEDED) Shared library: [libusb-1.0.so.0]
0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
Thank you!
I guess I’ll wait for the upgrade. I don’t get why the piaware was marked as “dead”.
After Upgrade of Ubuntu 19 amd64 to Ubuntu 20 amd64, piaware.service became masked. Why? dont know.
/etc/systemd/system/piaware.service -> /dev/null
abcd@ubuntu:~$ sudo find / -name piaware.service
/var/lib/systemd/deb-systemd-helper-enabled/default.target.wants/piaware.service
/var/lib/systemd/deb-systemd-helper-masked/piaware.service
abcd@ubuntu:~$ ls -l /etc/systemd/system/piaware.service
lrwxrwxrwx 1 root root 9 May 23 14:41 /etc/systemd/system/piaware.service -> /dev/null
SOLVED
Still had piaware_builder
and inside it piaware .deb package
which I have built on Ubuntu 19.
Purged, then reinstalled, and all is normal now.
$ sudo dpkg --purge piaware
$ cd piaware_builder
$ sudo dpkg -i piaware_3.8.1~ubuntu1904+1_amd64.deb
$ sudo piaware-config feeder-id xxxxxxxxxxxxxxxx
$ sudo piaware-config allow-auto-updates yes
$ sudo piaware-config allow-manual-updates yes
$ sudo systemctl restart piaware
lucpo1
May 24, 2020, 9:29pm
60
I installed packages from point 2.1
I have the same output for both commands like you. But I have still the same error. How can I fix it?
lucpo@ubuntu18:~/dump1090-fa$ dpkg -S librtlsdr.so.0
lucpo@ubuntu18:~/dump1090-fa$ readelf -d /usr/lib/x86_64-linux-gnu/librtlsdr.so.0 | grep NEEDED
@lucpo1
Seems some of the dependencies in step 2.1 did not get installed properly.
Purge these 5, then reinstall these 5.
Do it one by one and keep an eye on output of each command to find where the problem has occurred.
Do it slowly and carefully so that you dont miss any one of these 5 purges and 5 installs
sudo apt purge lighttpd
sudo apt purge librtlsdr-dev
sudo apt purge libusb-1.0-0-dev
sudo apt purge libncurses5-dev
sudo apt purge libbladerf-dev
sudo apt install lighttpd
sudo apt install libusb-1.0-0-dev
sudo apt install librtlsdr-dev
sudo apt install libncurses5-dev
sudo apt install libbladerf-dev
After completing above, go to step 2.2
lucpo1
May 24, 2020, 10:40pm
62
I purged these 5 and then reinstalled. There were no errors. The same error.
If it is not due to dependencies, then it may be due to corrupted debian/rules or some other file in cloned source code.
Delete cloned folder
sudo rm -rf dump1090-fa
Now clone fresh copy of source code by repeating step 2.2 from begening:
git clone https://github.com/flightaware/dump1090 dump1090-fa
lucpo1
May 25, 2020, 1:03pm
64
Every time I clone fresh copy of source code. Still the same error.
