You installed that with my script yes
What does it say about what the airspy-conf is compatible with?
Plug it in and run the script i donāt see any issues.
By all means try it first without going up the ladder.
It shouldnāt make reception worse.
The airspy will be just fine without an LNA if the antenna has good gain.
Itās just that when you spend the money for an airspy mini itās usually worth it to also pick up a filtered LNA so itās being used to the full potential.
And Iāve just read through your script on Github and donāt see anything in there about Airspy?
Youāll have to bear with me because Iām new to Pi/Linux and the only thing Iāve ever āprogrammedā in my life would have been something like this back in the 80ās;
10 PRINT āGlynā
20 GOTO 10
Iām just being overly cautious as my setup started out with a non-standard installation of rbfeeder and has been modified from thereON with more than a little help from abcd spread across several forums and although I have spent hours reading many threads on various forums and following his instructions I wonāt pretend I understand most of it.
Yeah the Pi is in the side of the loft closest to the external antenna with 2m Westflex 103 snaking its way in from outside where the Watson Radar Extender sits about 5m up a pole. Itās 1m tall with 3 small radials at its base and purported to have a 6dB gain which I always take with a pinch of salt but its been a great antenna since 2008 and still seems to be going strong.
I also purchased at that same time the very narrow band Kuhne 1090 A TM LNA which has a claimed 30dB gain with a noise figure of 0.5dB but also has a built-in two-pole band pass filter 1070-1110MHz between the two amplifier stages but apart from that one brief outing it has spent the rest of its life back in its box! Figured now might be the time for it to shine!
Iām just putting my ducks in a row and trying in vain to understand what it all means before I attempt to install airspy-adsb using your airspy-conf script from your Github and plugging in the Mini.
dump1090-fa or readsb needs to be installed before you run this script otherwise the script canāt change the configuration. It should work very well for example on a piaware-sd card image A normal Raspbian sd card image also works well. (On a Raspberry Pi the script will even install dump1090-fa for you if itās not present)
Well if you configured fr24feed and rb24feed correctly to use dump1090-fa data ā¦ itās all good. Raspbian Lite: ADS B receiver Ā· wiedehopf/adsb-wiki Wiki Ā· GitHub
Just for good measure iāll recommend using my dump1090-fa install script ā¦ it will fix pretty much all issues i ran across. (as you might guess iāve become tired of fixing issues with fr24feed configurations and dump1090-fa and left-over dump1090 files)
Well except for rbfeeder ā¦ a setup from the ground up is explained in the link above.
So ā¦ if you screw something up just start fresh or try on a 2nd sd-card.
Anyhow once you have dump1090-fa or readsb running as your decoder and none of the feeders try to occupy the SDR ā¦ only thing wrong can be the feeders not working and well i donāt care about that.
airnav and fr24 both have terrible feeder software ā¦ fr24 probably worse.
Well read the scripts then ā¦ try and understand how the TCP connections between all the programs work.
Look at the journalctl log ā¦
Already told you just run the script. I did that because i knew you had dump1090-fa running and thatās all that is required.
Other details of the setup donāt matter.
The feeders just connect to dump1090-fa and get the data from there ā¦ that interface isnāt changed by the airspy script.
Before you start making any modifications or running any scripts for āAirSpy miniā, make a backup copy of your microSD card on your Windows PC using Wi32DiskImager. It may take about 10 minutes to 30 minutes depending on microSD card size and speed of your Windiws computer.
This backup will make it easy to revert to your current working system if something goes wrong during attempt to add AirSpy mini.
Earlier today (just prior to installing piaware) I took two SD Card backups but I normally use SD Card Copier from the Accessories menu on the Pi itself.
I also have saved two SD Card copies of my Pi-hole machine and of a vanilla Pi just ticking away doing nothing really but waiting for its chance to step into the breach in case of hardware failure.
Oh Iāve already read your airspy-conf GitHub and most of your scripts & stuff already and keep coming back for more! Iām learning slowly but its a lot to take in especially when Iām wading through 500/600/800 post threads on similar subjects also.
Although some of my questions are answered by all of this reading sometimes it seems like more questions arise so thatās usually when I end up posting for clarification.
If it gives you some idea I purchased my very first Pi4 in October 2019 for the sole purpose of running Pi-hole but it wasnāt until October 2020 that I plucked up enough courage to install it!
Firstly- the bad news is Iām moving soon so my site will likely go off air in a couple of months. Dissapointing, but unfortunately the downside of a moveā¦
I had tweaked various values over the pandemic- trying to squeeze out as much as possible but possibly not in the most scientific way. Currently I am running:-
I have an Uptronics filtered preamp- so the gain reduction makes sense I think. It means Iām not overloading for near traffic- the downside is Iām probably not quite seeing as far as I used to.
Iām not sure what else infucences the āothersā category though.
Right now, Iām seeing around 1400 messages/sec (Iāve seen over 2200 in ānormalā times) and about 18% of that is being MLATād.
I was never quite convinced the higher sample rate really made much difference either.
Itās been so long since I adjusted mine, I had to go look in the history on my tracker to remember which file I needed to edit!
Iām running gain at 13 and the options:
OPTIONS= -v -f 1 -e 9.9 -w 5 -t 300
Sample rate is 20.
If I take e any higher, I start getting dropped samples and thatās when the āothersā start climbing up and my gain is optimal for here with the RTL-SDR LNA.
I noticed it a few weeks ago but Iāve had a lot on my plate with two family bereavements recently so didnāt even think to mention it. It was quite obvious because the count went up from being low to the multiple hundreds but as it was over a month ago, that data has disappeared from your stats page now.
No chance of getting a receiver up where youāre going to?
Iāve very sorry to hear that news. I hope you and family and managing ok. Been a very weird year this hasnāt itā¦
In the longer term maybe- we are moving witih work really so temporary location for a while. Will make it tough to set anything up for now and the Reading location was pretty good in terms of itās coverage.
If I was staying in Reading I would like to have looked at using three directional antennas to see if the agregate was better than an omni. Also wanted to have a look at space diversity which should work well at these frequencies and distances too. Alas there is never enough time for some of these projectsā¦
Thanks for that advice too wiedohopf!
On the basis of that and Keithās feedback Iāve updated too:-
OPTIONS= -v -f 1 -b -p -e 10.7 -w 4 -t 300
Iāll give that a go and see how it goes for a few days.
The ābā enables bias power. So Iām powering the Uptronics amp using that approach rather than an external micro-usb.
The āpā option enables āpackingā over the USB interface which as I understand uses the USB bandwidth more effectively. I think I needed that for āpeakā rates at the 20 MHz sample rate. Wasnāt an issue for 12 MHz I donāt think.
The āpā option might be useful for you? It may allow you to run a higher āeā value? I think it was the combination of high āeā and the 20 MHz sampling that drove me to that if I recall correctlyā¦
Oh my, I added -p, set -e to 10.0 (from 9.9) and wallop, thousands upon thousands of lost samples! I expect them for a few seconds after restarting the service but they just carried on and on.
