I am seeing an interesting behavior with message counts after a change to NET= in the airspy_adsb config file.
I am running 2.2-RC30-test successfully for several months now. I have this installed on a Piaware image. Running the latest 7.1 of Piaware.
I was looking at the contents of airspy_adsb.default and noticed that the default for NET= is not what I had configured.
I had NET= -l 47787:beast
Where the default is NET= -l 47787:beast -c 127.0.0.1:30004:beast
So I added the -c argument to my config and restarted airspy_adsb and immediately noticed two things.
Without the -c argument, I would see this in the log file after a restart of airspy_adsb.
Feb 08 15:17:02 airspy airspy_adsb[340]: Client connected from 127.0.0.1:45508 (beast)
Feb 08 15:17:02 airspy airspy_adsb[340]: Client disconnected 127.0.0.1:45508 (beast)
Feb 08 15:18:20 airspy airspy_adsb[340]: Client connected from 127.0.0.1:45532 (beast)
With the -c argument, the logs show this after a restart.
Feb 11 09:40:21 airspy airspy_adsb[15946]: Push client connected to 127.0.0.1:30004 (beast)
Feb 11 09:41:20 airspy airspy_adsb[15946]: Client connected from 127.0.0.1:54460 (beast)
And that looks reasonable.
However, on the tar1090 side panel, I immediately noticed that my message rate jumped to almost double the msg/s rate before the change. With about 150 aircraft seen, the message state is close to 1200 msg/s whereas before it was closer to 600 msg/s. Please note that the number of aircraft did not double.
Also in graphs1090, in the ADS-B Message Rate Graph and ADS-B Maxima, I see a corresponding jump in message rate. But, Aircraft Seen/ tracked, ADS-B Message Rate / AC and DF counts see no indication of “data doubling”.
So my question is this. Are the ~1200 msg/s rates I am seeing in tar1090 and the ADS-B Message Rate and ADS-B Maxima Graphs in graphs1090 with 150 aircraft accurate message rates at the higher value or has the default NET= setting resulting in reporting a doubling of messages? And if it is a doubling message, should the default for NET= really be NET= -l 47787:beast -c 127.0.0.1:30004:beast?
Inquiring minds would like to know.
