FlightAware Discussions
HOWTO: Airspy mini and Airspy R2: Piaware / dump1090-fa configuration
The previous lines were two hours earlier, that’s why I didn’t include them
Sep 15 15:14:14 g0pkt-piaware airspy_adsb[31142]: CPU 75.2 %, target 85.0 %, adjusting preamble filter: 5 -> 6
Is the one directly above. I doubt that’s related.
No, it was several hours after the last decoder start.
Pi was booted days ago.
Did I induced any nightmares? Sorry! :rofl:
LE: For anyone there, Widenhopf stayed up late (his time zone) and helped me troubleshoot my lock-ups of airspy_adsb at reboot. I am grateful!
@wiedehopf is our hero :slight_smile:
2.2-RC15
  • -C cpu target algorithm improved to react much quicker and finer, will no longer announce adjustments in the system log. non-integer preamble filter possible again by timesplitting between two preamble filter settings
  • -P is a secondary preamble filter which is useful when encountering
    wrong altitudes or planes showing ground in VRS, it will only apply to
    non-CRC messages, such as most non-position messages. Of course the drawback is that the number of correct messages of that category are slightly reduced as well.
    (try -P 5 or even less if you run high -e settings and have an issue with wrong altitudes)
Have you stopped printing -e changes? After this update Graphs1090 still shows it but the log does not.
Changes are too quick to print them, it would flood your log.
Good to know. Seems to be much more solid here. Good change. Thank you.
@wiedehopf Thanks for doing that! I’m anxious to experiment with it.
I pushed -C to 65 and all altitudes in VRS look correct - no GND!
-v -t 60 -f 1 -w 5 -e 4 -E 25 -C 65 -D  -P 5
airspy-localhost-misc-2h
How about impacts of that to message rate?
-e at 15, testing -P 2 and -P 1, not seeing issues. CPU usage down the same with either. And no GND in VRS watching for a few minutes with 45 to 50 aircraft. Normally at -e 15 I would see maybe 3 to 5 GNDs at any given time with 50 or so aircraft. Not a single GND seen yet. Message rate, who knows, but nothing obvious is visible.
I’m assuming -P 1 is less filtering than -P 5, like -W
chrome_tdzunK8g42
Further testing. Looking for bad altitude readings with -P 1. Well there are none!
Usually at -e 15 I get a lot of aircraft with final altitude reading being very bogus as they drop out of range. Like all these dark orange/maroon planes. Hundreds of bad altitudes in this image.
But with -P 1 and -e 15, not a single obvious bogus reading yet!
Edit
One more, you can really see the weakest messages are filtered out with -P 1 in the ADS-B signal graph. I’m not seeing any ill effects from this. Planes changing altitudes live on the map appear to be changing in 25 feet increments up/down every second or two like normal.
Just for reference, the same timeframe Airspy graphs.
Please read what exactly it is, i’ve described it.
It works like a secondary -e for messages that don’t have CRC.
So 1 is actually the most restrictive version currently available.
Each message has preamble, so something that starts every message regardless of type.
It’s a certain pattern and the preamble filter looks for that pattern.
With high -e, the preamble filter is less restrictive, so … anything that remotely “looks” like that pattern is let through and decoding is started.
-P uses that same check again with a different factor when a potential message has already passed the main preamble filter and the message type is known.
-P 1 is the same for non-CRC messages as -e 1 would be for all messages.
If you’re really curious about how those options affect the numbers, record a local sample and test on that.
Thanks, I guess I did misinterpret the release notes. Makes sense. Testing -P 5 now. I already see a GND after 2 minutes with under 20 planes. So now I have a reference of -P 1 and higher. :grinning:
With RC14 and below using -C 85 and no -E set, I was getting -e to go up to around 36 or so… With RC15 I had the same… I checked VRS and noticed a few GND planes… So set -P 5, however now -e has shot up to nearly 50…
So I’ve now set -E 39 and will run with that for a bit.
So? :slight_smile:
With -P 5 or whatever setting you choose, increasing -e isn’t an issue usually as the less selective -e only applies to CRC messages.
Thanks for the detailed description.
I don’t think I need to use -P.
2.2-RC16
  • slight change to the json to support more data in graphs
  • minor bugfix: watchdog could falsely trigger on startup
This will hopefully be the last RC if there are no bugs.
some red, orange, yellow to be added and we have rainbows :wink:
