If you have a secure password on ssh or better still a secure file then that would prevent that.
When I mentioned about allowing incoming connections it is the port 30005 and related connections plus dump1090 web connections that I was referring to.
I suppose if you know exactly what ports FA, FR24 and others actually use then you could deny all connections and open them up.
Does not change gain by dropdown + “Set Gain” button
Does not change gain by command
sudo echo 16 > /var/html/setgain/newgain -bash: /var/html/setgain/newgain: No such file or directory
I have done following
(1) Created file /usr/local/sbin/setgain.sh and copy-pasted code from your post rev3
(2) Entry in cron sudo crontab -e, and added following line @reboot /bin/bash /usr/local/sbin/setgain.sh
(3) In file /usr/share/dump1090-fa/html/setgain.php, I have done following 2 changes:
Read file /var/www/html/setgain/newgain and displayed output in red as Current Gain: <div><font color=#ff0000 face="'Helvetica Neue', Helvetica, Arial, sans-serif">Current Gain: <?php system('cat /var/www/html/setgain/newgain');?> </font></div>
Commented out following line system("/var/www/html/setgain/setgain.sh $gain >> /tmp/gain.log 2>&1");
(3) to read the current gain it needs to read /var/www/html/setgain/currentgain
to set gain you need to do an system("echo 33 > /var/www/html/setgain/newgain")
with the gain value.
Now to the actual problem: the echo should be working and it should be working without sudo
as well as with sudo
the script is probably not running.
try sudo /bin/bash /usr/local/sbin/setgain.sh and see what it does.
probably needs an sudo chmod u+x /usr/local/sbin/setgain.sh (hmm no that’s not needed when starting it with bash)
All this was just an rough outline i kinda assumed you were a bit more familiar with all the scripting stuff as much as you have done.
But with these changes it should work. All that is for the piaware card.
For the sed version you would need to put that in the setgain.sh
/usr/local/sbin/setgain.sh: line 2: /var/html/setgain/log: No such file or directory
mkfifo: cannot create fifo '/var/html/setgain/newgain': No such file or directory
Nice thing about a suggestion is - you don’t have to take the advice.
Of course it helps, two padlocks on a door is more of a deterrent that one, why do you think the private/public key pairs also have an ‘option’ for a password. An extra lever of security.
Yes, two lines in your code I have changed as follows (commented out lines are from your code, uncommented are replacement I provided)
Still not working in package install.
Will now burn Piaware SD card image and try your script on it.
# piaware-config -show rtlsdr-gain > /var/www/html/setgain/currentgain # read current gain so it can be read out
awk '{for(i=1;i<=NF;i++) if ($i=="--gain") print $(i+1)}' > /var/www/html/setgain/currentgain # read current gain so it can be read out
# piaware-config rtlsdr-gain "$line" #set new gain
sed -i '/RECEIVER_OPTIONS=.*/c\RECEIVER_OPTIONS="--device-index 0 --gain '$line' --ppm 0 --net-bo-port 30005"' /etc/default/dump1090-fa #set new gain
Setting the gain looks correct so far.
Please provide the log so i can check in case something else is a problem in the script.
Running the script on the shell may be easier than via the cronjob at first.
This does not work. You need to cut the second redirect (everything after and including >>)
(you could just redirect errors with 2>/tmp/gain.log but i don’t really see the value)
Yes, I have already discovered this and corrected it, but it it still fails. When I change gain, the dump1090-fa fails to start because for some reason the in file /etc/default/dump1090-fa, the value after --gain is blank. The $line seems to be empty. Either it is not read from newgain or the dropdown gain value is not passed to file newgain
