hi my setup for windoze and rpi3 (B+). getting input from Planeplotter 30303.
broken down command line for readability’s sake.
must not use - (dash) as program tries to interpret it as command. so ADS_B is ok but ADS-B is error…
underscore (_) is prefered.
Reading package lists... Done
Building dependency tree
E: Unable to locate package libssl.so.1.0.0
E: Couldn't find any package by glob 'libssl.so.1.0.0'
E: Couldn't find any package by regex 'libssl.so.1.0.0'
I hope it Will be possible to just correct it, because the rpi is on a remote location, So I’d rather don’t want to create another SD card
pi@raspberrypi:~/mm2 $ ./mm2.sh /home/pi/mm2/modesmixer2_rpi1: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
pi@raspberrypi:~/mm2 $ sudo apt-get install libssl1.0.0 .... .... .... Package libssl1.0.0 is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package 'libssl1.0.0' has no installation candidate
hi abcd
did you try it on your Ubuntu machine ? trying to setup a Debian VM now and will adv.
however dont know about pi, as i still use jessie.
brgds evangel
@katwijk
Meanwhile, pending solution for Stretch on B+, you can burn a spare microSD card with Jessie image or Piaware SD card image (which is also Jessie) and use it with your Pi B+. This combination works OK with modesmixer2_rpi1.
ok mm2 v Sep/2017 works in vbox VM debian 9. however impossible so far to run it under qemu arm-VM
due lack of another rpi.
strange thing is that libssl.1.1.0 exist in /usr/lib/arm-linux-gnueabihf/
I know its an old thread, but Im upgrading my B+ to a 3 this week (its on the way) and wonder what course of action for upgrading you would recommend. 3 should run the B+ SD card just fine.
it works, but it takes some time till MLAT a/c are coming up … be patiently and wait
(I installed all the stuff several times, but every time no MLAT showed up)
Hopefully when you slip your B+ microSD card in Pi3 and power up, it should work ok, but I am not sure as I never tried it (dont have Pi3, have only Pi B+ and Pi2). You will know when you try it.
I am sure of one thing: your modesmixer2 install for B+ is not going to work in Pi3. You have to delete the mm2 folder with its contents by following command:
sudo rm -rf mm2
Afrer deleting mm2 folder, make a fresh install of modesmixer2 using method described for Pi2/3
