How to feed Realtraffic.com
Hi all,
I am running the Wiedehopf’s airspy_adsb. (and it work very well)
Now i want to feed www.flyrealtraffic.com
The setup says:
  1. Edit your readsb config file:
    sudo nano /etc/default/readsb
  2. Add the following to the NET_OPTIONS line (replace with your UUID from above):
    --net-connector feed.flyrealtraffic.com,30004,beast_reduce_plus_out,uuid=
  3. Restart readsb:
    sudo systemctl restart readsb
I have no readsb file, only the airspy_adsb file. That file does not support Net_Options.
Is there a solution i can feed with airspy_adsb?
Greetings,
Ruud
I am curious to know if this site is similar to other aggregating sites, or it has something different / special?
This website is a feeder for real adsb-traffic in Microsoft Flightsimulator.
Then install readsb? (don’t worry if it says it can’t find an SDR)
Automatic installation for readsb · wiedehopf/adsb-scripts Wiki · GitHub
And then re-run airspy-conf install script (you’ll have to redo your airspy options in the config file). GitHub - wiedehopf/airspy-conf: Configure airspy_adsb for use with readsb or piaware. · GitHub
It will modify the readsb config to get data from airspy_adsb.
still not working :thinking:
i followed the steps wiedehopf has given me…
the readsb-config file is empty and there is no readsb.service.
then you didn’t install via that script.
or it told you it’s a piaware image. then it won’t install.
use a raspbian image then.
or don’t feed real traffic if they don’t provide a script to install their feed … not that hard to make such a script and have another readsb run just to feed them.
in other words: get better at reading and good luck :slight_smile:
I used the script but i get a warning about the piaware image.
I will try a raspian image :wink:
Thank you for the feedback
It’s up and running. (now on a rpi5)
thank you for the helpfull tips wiedehopf
