How to Edit Account Site Location
Hi. I had to reinstall the software on a pi and when reconnecting it looks like I chose the incorrect airport location. On my account, how do I
A. Delete the incorrect location;
B. Add the correct location;
C. Add latitude and longitude to show my exact site?
Evidently, I have one account with 3 location airports listed.
Help!
Stewart
Hi,
In order to edit your location you have to login to your FA account.
Then go to My ADS-B in the top banner and select Stats.
After this page is loaded you can see a cogwheel on the right side of the page.
Click it and it wil open the Site configuration page.
There are some things you can edit there and one of them is the nearest airport option.
You can select the correct airport there and also edit the exact location and height of your reciever.
afbeelding
You can select the location via a map or with exact coordinates (if you know those).
The antenna height can be set above ground level in meters of feet. Other option is to set it above sea level
That should enable you to set the correct location and height for your antennas
