I hope someone can help me with the following; I have a basic RPi 3 set up with a Flightaware Pro stick which until a few weeks ago worked flawlessly. In the last three weeks the RPi lost connection a few times without apparent reason. I’m wondering what the best way is to diagnose the actual the problem?
I actually did not touch the set up (at all) and a simple reboot fixes the connection, but I’d like to understand what’s happening. Unfortunately I’m neither an expert the electronics nor the RPi, but perhaps someone can give me some pointers i.e. how to best review the log, do error checking etc.
This comes up quite often - the RPi is working, but not decoding. A reboot fixes the problem for a while, but then it fails again - sound familiar?
If so, bin your PSU and find something better. Phone chargers are notorious for short lives when used continuously.
There are power supplies specially for the Raspberry Pi which supply 5.2 V (Official Raspberry power supply and Canakit power supply for example)
If you can buy one of those.
Looking for the terms in the rest of the forum reveal that it’s generally preceded by some kind of warning (e.g. 'no data received) but that’s not the case. I guess that does not conclusively rules out hardware (e.g. USB or PSU ) but any other thoughts on this?
It’s probably being restarted by piaware, you should check that log as well. journalctl -eu piaware
Or you can just check the complete journal. journalctl -e
If piaware tries to restart dump1090-fa it’s almost always because of the PSU issue.
Is your dongle connected directly to the RPi? USB cables often have a voltage drop.
You can also connect it to the RPi via a powered USB hub, that way the dongle gets enough power.
