How is your reception lately? (WSPR, ADS-B, SatNOGS, etc.)
Damn, you’re really taking it to the next level! My lazy DIY setup is doing just fine, but your dedication makes me curious—what are you hunting for?
@SHIRAKAMI
Wow, your data is 1,500 packets a day, mine only 60 packets a day. No comparison.
How did you achieve that high reception?
Honestly, I just put it like this by the window, and one day it suddenly started pulling in tons of packets out of nowhere. I have no idea why either! :joy:
Just to follow up, here is the current status! Not bad for a super lazy window setup, right? Over 7,500 confirmed packets and 63% SatDex completion. Who needs fancy filters when you have a bamboo blind? :joy:
@SHIRAKAMI
Wow…this is fantastic! My best day is still under 600 packets.
Looks like I’ll have to re-visit my setup.:grinning_face:
I’m sure a Raspberry Pi would work.
Since most decodes are from Tianqi sats, I wonder if because this sat family is chinese they have passes optmized for China and transmit more packets when over China. Japan likely being in the footprint of the sats receive most of those packets as well.
I say this because I’ve seen “perfect” passes with very few packets decoded and other passes barely visible with more decodes.
All speculation on my part of course.
That makes total sense! I was actually wondering why there are so many Tianqi packets. You might be right about the geographic advantage and satellite footprint. Either way, I guess I was just super lucky with this setup!
@Dxista
I feel in addition to his nearness to China, other factors for better reception by @SHIRAKAMI are
(1) His is a dipole, while mine is a spider.
(2) His dipole is projecting out few cm, bringing it better view of sky, mine is totally recessed inside.
I am now considering to replace spider by a dipole.
With the help of my “good friend” Gemini I trimmed my RadioShack Discone Sputnik antenna to 433MHz in the hopes that performance would improve. Nothing so far. :frowning:
Even the best antenna cannot receive a packet which is NOT transmitted by a Satellite. :rofl:
So true!
I’ll leave it alone, back to optimizing my Meshcore Observer.
Maybe TIANQI is actually transmitting in Chinese characters (kanji)! It’s a secret feature so only people in China and Japan can decode it :joy:
@abcd567
@SHIRAKAMI
After 2 days since trimming/tuning the antenna to 433 MHZ, the number of packets decoded increased by 40% over the previous 30 days average.
If I compare to the highest day over the previous 30 days, the increase was of around 20%, still a very good “return”.
In addition to that, a new distance record of 3187.9 Km was recorded today.
The other surprise was finding out that even before the antenna trimming/tuning my ground station was already doing very well in the North America “theater”.
I also think that my “guess” about Tianqi passes being optimized for China applies. Japanese ground stations do extremely well compared to North American ground stations.
All in all a nice surprise.
A new multimode decoder for both Windows and Linux.
It’s still in alpha stage, lots of bugs, but good enough to test.
Works great with the RTL-SDR stick.
@Dxista
@SHIRAKAMI
@jimMerk2
Got Wilkinson Splitter/Combiner and setup 403MHz and 433MHz SAW filters .
SCHEMATIC
SETUP WITH 2xWILKINSON SPLITTER / COMBINER
CLOSEUP
I think you might have a problem with that configuration. You will have about 9dB loss at each of your SAW filter frequencies.
3dB from each of the splitter/combiners and about 3dB from each of your SAW filters.
403 MHz path 3dB splitter loss, then 3dB filter loss and then 3dB combiner loss.
The 433 MHz path is the same, so you will have a noise figure of around 10dB at each of your wanted frequencies.
It will be interesting to see if you actually get any better performance than just an antenna straight into the receiver,
(1) Antenna >> Receiver = Very few packets/day
(2) Antenna >> LNA >> Receiver = Zero packets/day.
(3) Antenna >> LNA >> 403MHz filter >> Receiver = Zero packets/day
(4) Antenna >> 403MHz Filter >> LNA >> Receiver = highest number of packets/day
(5) Antenna >> 433Hz Filter >> LNA >> Receiver = moderate number of packets/day
(6) Antenna >> Wikinson Splitter >> 403MHz + 433MHz filters in parallel >> Wilkinson Combiner >> LNA >> Receiver = Zero number of packets/day
Only (4) and (5) give acceptable results. The (4) is higher than (5) because number of 403MHz Satelite passing over my location are higher than the number of 433MHz Satellites passing over my area.
NOTE:
The RF interference by Cell signals at my location is too high. Even FA Antenna + FA ProStic gave very poor result, and only after adding an FA external filter, I could get a good performance.
I expect you need a similar approach but with a filter that has a passband of say 390 MHz to 450 MHz
Unfortunate such filter is not available from online market places like amazon, ebay, aliexpress
I asked AI to give me design of a LC filter with pass-band 360MHz to 500MHz. I got the design, but due to my poor soldering skill and not so sharp vision, it is not possible for me to implement this filter consisting of SMD components.
https://discussions.flightaware.com/t/how-is-your-reception-lately-wspr-ads-b-satnogs-etc/100643/451
