How is your reception lately? (WSPR, ADS-B, SatNOGS, etc.)
:+1: :+1: :+1: good idea.
@jimMerk2
@Dxista
@SHIRAKAMI
@geckoVN
Another Venture With Google AI Gemini :wink: :winking_face_with_tongue:
NOTE:
Responce of AI is NOT yet verified
It can be verified by Windows Sotware “Elsie” (LC)
Student Edition, Free of Cost
https://www.tonnesoftware.com/elsie2.html
(1) INPUT TO AI
I am attaching photo of LC Bandpass filter for 10MHz. I want to remove all capacitors and inductors on this pcb by SMD capacitors and inductors of values which will convert this pcb into a 380MHz to 480MHz bandpass filter. Can you give me values of C1, C2, C3, C4, C5 and L1, L2, L3 SMD which I should use as replacement?
AI RESPONSE:
To convert this specific BG7TBL 10M BPF PCB into a 380 MHz to 480 MHz bandpass filter, you can substitute the components using a standard 3rd-order configuration.
The PCB layout features a classic multi-pole geometry: the top row contains horizontal series positions, while the bottom row contains vertical shunt positions tied to ground. Because 380–480 MHz borders the UHF band, using standard E24 series component values keeps your modifications practical while accounting for parasitic board capacitance. [1]
Standard SMD Component Replacement Values
For optimal performance at these higher frequencies, use high-Q RF capacitors (like Murata GRM series) and high-Q wirewound RF inductors (like Coilcraft 0603HP or similar) in an 0603 size package.
Component Label Component Type Component Role Ideal Value Recommended E24 Buyable Value
C1 Capacitor Input Coupling 50.8 pF 51 pF
C2 Capacitor Interstage Coupling 1.6 pF 1.5 pF or 1.6 pF
L1 Inductor Interstage Resonance 87.3 nH 82 nH or 87 nH
L2 Inductor Output Resonance / Match 87.3 nH 82 nH or 87 nH
L3 Inductor Input Shunt Tank 2.7 nH 2.7 nH
C3 Capacitor Input Shunt Tank 50.8 pF 51 pF
C4 Capacitor Center Shunt Tank 50.8 pF 51 pF
C5 Capacitor Output Shunt Tank 50.8 pF 51 pF
Critical UHF Modification Advice
  1. Parasitic Traces: At 430 MHz, the existing copper traces on a PCB designed originally for 10 MHz will introduce minor parasitic inductance and capacitance. You may need to slightly lower the value of C3, C4, and C5 (e.g., down to 47 pF) if you find the center frequency shifts slightly lower than expected on your vector network analyzer (VNA) or spectrum analyzer. [1]
  2. Solder Cleanliness: Ensure all flux residue is thoroughly cleaned off using isopropyl alcohol. Leftover flux introduces parallel resistance and extra capacitance, which degrades the insertion loss at UHF frequencies.
Would you like assistance in choosing between wirewound vs. multilayer SMD inductors for this frequency band, or do you need help interpreting your analyzer’s trace window after mounting the parts?
python
import math
f1 = 380e6
f2 = 480e6
f0 = math.sqrt(f1 * f2)
bw = f2 - f1
Z0 = 50.0
# Chebyshev 0.5 dB prototype values
g1 = 1.5963
g2 = 1.0967
C_shunt = g1 / (2 * math.pi * bw * Z0)
L_shunt = 1 / ((2 * math.pi * f0)**2 * C_shunt)
L_series = (g2 * Z0) / (2 * math.pi * bw)
C_series = 1 / ((2 * math.pi * f0)**2 * L_series)
print(f"C_shunt: {C_shunt*1e12:.2f} pF")
print(f"L_shunt: {L_shunt*1e9:.2f} nH")
print(f"L_series: {L_series*1e9:.2f} nH")
print(f"C_series: {C_series*1e12:.2f} pF")
[1] https://www.reiding.com
Input to AI:
I want assistance in choosing between wirewound vs. multilayer SMD inductors for this frequency band
AI RESPONSE:
For the 380 MHz to 480 MHz (UHF) frequency band, you should exclusively choose wirewound SMD inductors. [1]
Using multilayer inductors in a passband filter at this high of a frequency will result in high insertion losses and a poorly defined filter shape. Below is a direct comparison explaining why wirewound is the mandatory choice for this modification. [1, 2]
Multi-Object Direct Comparison
Feature / Metric Wirewound Inductors (Ceramic Core) Multilayer Inductors
Q-Factor (Quality) High (typically 30 to 100+) Low to Moderate (typically 15 to 40)
Self-Resonant Freq (SRF) Very High (Safe for 400+ MHz use) Lower (Can resonate too close to the passband)
DC Resistance (DCR) Very Low (Thick copper wire turns) High (Thin internal layered traces)
Inductance Tolerance Tight (±2% or ±5% available) Loose (Typically ±10% or ±20%)
Filter Performance Impact Sharp cutoffs, minimal insertion loss Blunted slopes, high signal attenuation
Best Used For… RF Filters, Impedance Matching Decoupling, Choking, Power supplies
Why Wirewound is Mandatory for Your 400 MHz Filter
  1. The Q-Factor Penalty: At 430 MHz (the center frequency), a low Q-factor means the inductor behaves less like a pure inductor and more like an inductor in series with a resistor. Multilayer types have an integrated internal conductive paste spiral with high equivalent series resistance (ESR). If you use them here, the top of your passband curve on the analyzer trace will dip significantly, giving you a heavy insertion loss (several dB of lost signal strength). [1, 3]
  2. Sharpness of the Skirts (Selectivity): The series branch component L1 (82 nH–87 nH) is responsible for building a sharp cut-off directly after 480 MHz. Because multilayer tolerances are wide, your filter response will shift unpredictably. The lower Q will also “soften” the response, turning your sharp bandpass filter into a broad, shallow hump. [4]
  3. Self-Resonant Frequency (SRF): For an inductor to behave reliably in a filter configuration, its SRF must be well above the operational window. A wirewound 82 nH inductor in an 0603 size package keeps its SRF safely higher than 1 GHz. Multilayer parts approach their internal resonance much quicker, which can introduce parasitic capacitive behavior directly inside your 380–480 MHz passband. [5]
Part Procurement Tip
When sourcing your 0603 SMD parts, look for ceramic-core wirewound RF inductors from reputable manufacturers, such as the Coilcraft 0603HP Series or Murata LQW18 Series. Avoid generic “ferrite chip beads” or power inductors entirely. [1]
Are you planning to test this filter with a Vector Network Analyzer (VNA) or a spectrum analyzer with a tracking generator, and would you like a quick tip on how to handle the grounding traces when soldering these tiny 0603 components to the board?
[1] https://www.reddit.com
[2] https://passive-components.eu
[3] https://www.fastturnpcbs.com
[4] https://www.eoswell.com
[5] https://www.coilcraft.com
It would be nice if AI could provide a theoretical frequency response of the 400 MHz filter using the recommended LC values. Also, usually these circuit analysis programs can provide a range of freq responses as the L and C values vary over their respective ranges.
On Aliexpress, they are selling blank pcb for diy bandpass filter for C$5.35 + Shipping C$9.17
https://www.aliexpress.com/item/1005012550323981.html
Myself
I have a PCB with SMD Inductor and capacitor. PLEASE PLT RESPOC E CURVES s11 & s12 vs freq.. The PASS BAND IS 380mhz TO 480mhZ
AI RESPONCE
Here are the plotted S-parameter response curves S11 and S21 simulated for your specific discrete lumped-element bandpass filter spanning the 380 MHz to 480 MHz passband.
Frequency Response Curves S11 and S12
The plot below illustrates the simulated behavior using your standard E24 component values:
(Note: Because this is a 2-port passive filter network, S12 is identical to S11 due to reciprocity, and S22 mirrors S11 in a symmetrical or well-matched design.
Key Performance Insights
  • S21 (Insertion Loss / Transmission): Inside the 380 MHz to 480 MHz green window, transmission is maximized. A realistic insertion loss of around -1.2 dB to -1.5 dB is expected due to the parasitic series resistance (ESR) of the SMD inductors. Outside this band, the signal drops off sharply, providing excellent out-of-band attenuation below 300 MHz and above 550 MHz.
  • S11 (Return Loss / Reflection): Inside the passband, S11 drops significantly below -15 dB, indicating a highly efficient match with very low power reflection back to the input source. Outside the passband, it approaches 0 dB, completely rejecting and reflecting out-of-band frequencies.
Circuit Performance Recommendations
  1. Inductor Tolerances: Since your table chooses standard E24 components (e.g., using 82 nH or 87 nH instead of the ideal 87.3 nH), expect a very slight shift in the center frequency or minor asymmetry in the passband ripple.
  2. Parasitics: Ensure your layout features short, direct trace routing to minimize parasitic track inductance, which could inadvertently skew the filter’s high-frequency corner down from 480 MHz.
Would you like to simulate how a shift in component tolerance (e.g., ±5% variation in your inductors) affects the passband limits, or do you need help calculating the microstrip trace widths to guarantee a 50 Ω environment on your PCB?
I would answer yes to that.
Too late, I have already closed that session with AI couple of hours ago.
Anyway for LoRa LEO tracking case, a shift of 5% in 380~480 MHz band is not critical as the frequencies of interest are 400, 401, 436, & 437 MHz which are well within 5% tolerance.
If you want to be on safe side, then re-design the filter with pass band 360~500MHz instead of 380~480MHz.
@jimMerk2
Just for the sake of completeness, I asked Google AI to recalculate everything for 360MHz ~ 500MHz Band Pass filter. Here is the result.
HOTE: Due to my poor soldering skills, I wont be able to unsolder / solder SMD components from a PCB without damaging it. I am NOT going to implement this design. For me, this is only a n investigative excersise.
Myself to AI:
I am attaching photo of pcb of LC Bandpass filter for 10MHz. I want to remove all capacitors and inductors on this pcb by SMD capacitors and inductors of values which will convert this pcb into a 360MHz to 500MHz bandpass filter. Please give me
  • (1) values of C1, C2, C3, C4, C5 (smd) and L1, L2, L3 (wire-wound smd) which I should use as replacement
  • (2) plot response curve vs frequency , S11, S12 etc.
  • (3) simulate how a shift in component tolerance (e.g., ±5% variation in your inductors) affects the pass-band limits
This is the photo of 10MHz Bandpass filter, whose components I want to replace to convert it to a 360MHz - 500 MHz Band Pass filter
AI RESPONSE
Looking closely at the layout traces and silk screen designations of the uploaded image of your BG7TBL 10M BPF PCB, this board is configured as a 5th-order Elliptic / Cauer Lowpass or Bandpass filter topology. The components are arranged with two series branches (C1-C2 and L1-L2) and three shunt branches down to the ground plane (L3, C3-C4, and C5).
Because a 5th-order filter contains 8 independent reactive elements distributed across 7 SMD footprints (0805 or 0603 size), recalculating the network for a 360 MHz to 500 MHz bandpass filter changes the required component placements.
1. Component Values (360–500 MHz)
To achieve a sharp passband between 360 MHz and 500 MHz in this 50 Ω layout, the footprints must be populated to create a combination of series-resonant transmission zeroes and shunt-resonant pass-nodes.
Here are the target component values for the conversion:
  • C1: 3.3 pF (SMD, Ultra-low ESR, C0G/NP0)
  • C2: 4.7 pF (SMD, Ultra-low ESR, C0G/NP0)
  • L1: 8.2 nH (High-Q wire-wound SMD)
  • L2: 8.2 nH (High-Q wire-wound SMD)
  • L3: 12 nH (High-Q wire-wound SMD)
  • C3: 6.8 pF (SMD, Ultra-low ESR, C0G/NP0)
  • C4: 10 pF (SMD, Ultra-low ESR, C0G/NP0)
  • C5: 5.6 pF (SMD, Ultra-low ESR, C0G/NP0)
Note: Because this layout uses relatively wide traces between the components, the parasitic microstrip capacitance to the bottom ground plane at 500 MHz is significant (roughly 0.8 pF to 1.2 pF per node). If you find your high-frequency cutoff is pulling lower than 500 MHz on the spectrum analyzer, reduce C3, C4, and C5 by 1 pF.
2. S-Parameter Frequency Response (S₁₁ and S₂₁)
Because this layout forms a higher-order elliptic-type network, the stopband rejection rolls off much faster than a standard LC ladder filter. It introduces transmission zeroes just outside the 360 MHz and 500 MHz limits to flatten out the passband.
3. Tolerance Simulation (±5% Inductor Variation)
With a 5th-order elliptic filter, component tolerances are significantly more critical than in lower-order filters. Because the transmission zeroes rely on the precise interaction of series and shunt combinations, a ±5% shift alters both the passband slope and the return loss.
Modification Tips for this Specific Board
  1. Remove Grounding Parasitics: The original 10 MHz components are physically large. When you clear the board, use copper wick to remove all old solder completely. Extra solder blobs add stray inductance that will distort your 400 MHz wavefront.
  2. Component Orientation: When soldering your new wire-wound SMD inductors onto L1 and L2, orient them 90 degrees perpendicular to each other if their internal coils are visible. Because they sit right next to each other on this small board, keeping them perpendicular reduces mutual magnetic coupling which can bypass the filter stages entirely.
Would you like assistance identifying the exact SMD package size (such as 0603 or 0805) used on this BG7TBL board so you can order components that fit perfectly?
MYSELF TO AI
Yes, I would like assistance identifying the exact SMD package size (such as 0603 or 0805) used on this BG7TBL board so I can order components that fit perfectly
AI RESPONSE
The footprints on your BG7TBL 10M BPF board utilize the standard imperial 0805 package size. [1]
Dimensional Verification
You can visually confirm this directly from your board using the two edge-mounted SMA connectors as a structural reference:
  • 0805 components measure approximately 2.0 mm × 1.25 mm (0.08 in × 0.05 in).
  • 0603 components are noticeably smaller, measuring 1.6 mm × 0.8 mm.
  • The metal terminal pin on standard end-launch SMA connectors (the center pin extending onto the PCB trace) is roughly 0.8 mm to 1.0 mm wide. In the photo, the width of the C1 and C5 pads perfectly mirrors the wide footprint of an 0805 component rather than the much narrower 0603 footprint. [1, 2]
Ordering Tips for Your 360–500 MHz Conversion
When selecting your replacement SMD parts from distributors like DigiKey or Mouser, keep the following package rules in mind for high-frequency UHF performance:
  1. Capacitors (C1 to C5): Buy 0805 size ultra-low ESR, C0G / NP0 dielectric ceramic capacitors. Avoid general-purpose X7R dielectrics, as their capacitance drifts heavily across frequency and temperature.
  2. Inductors (L1 to L3): Order 0805 size high-Q wire-wound ceramic core inductors (such as the Coilcraft 0805CS series or equivalents). Wire-wound variants have a much higher Self-Resonant Frequency (SRF) than multilayer ferrites, which is crucial since you are operating at 500 MHz.
  3. Footprint Compatibility: If you happen to have 0603 parts on hand, they can technically be hand-soldered onto 0805 pads by spanning the gap with a slightly larger bead of solder. However, for a high-frequency filter, using exact-match 0805 components is strongly preferred to prevent adding extra stray inductance from the stretched solder joints. [3, 4]
Would you like me to look up the exact manufacturer part numbers or specific Self-Resonant Frequency (SRF) specifications for the 8.2 nH and 12 nH inductors to make sure they won’t choke your 500 MHz passband limits?
[1] https://www.protoexpress.com
[2] https://www.allpcb.com
[3] https://jlcpcb.com
[4] https://www.schemalyzer.com
ADDITIONAL INFO ON HAND SOLDERING SMD TO PCB
Physical Sizes (0805 vs. 0603)
Package sizes are coded by imperial dimensions in hundredths of an inch (length × width).
  • 0805: Measures 2.0mm × 1.25mm (0.08" × 0.05"). It handles higher power (typically 0.125W to 0.25W) and is very easy to hand-solder or prototype with.
  • 0603: Measures 1.6mm × 0.8mm (0.06" × 0.03"). It handles lower power (0.1W), saves more board space, and requires fine tweezers and steady hands for manual soldering.
  • Other common sizes include smaller 0402 (1.0mm × 0.5mm) and larger 1206 (3.2mm × 1.6mm).
For hand-soldering electronic components, 0805 components are significantly easier and highly recommended over 0603 components, especially for beginners or prototyping.
While both package sizes can be soldered by hand with practice, they offer very different experiences when using a manual soldering iron and tweezers.
Direct Comparison for Hand Soldering
Feature 0805 SMD Components 0603 SMD Components
Physical Dimensions 2.0 mm × 1.25 mm (Larger) 1.6 mm × 0.8 mm (Noticeably smaller)
Ease of Handling Easy to manipulate with standard tweezers. Requires very steady hands; easily lost if dropped.
Visibility Visible to the naked eye. Difficult to orient properly without a magnifying glass or microscope.
Solder Joint Margin Forgiving; larger pads provide a clear target for the iron tip. Unforgiving; easy to accidentally bridge or “tombstone” (component stands vertically).
Power Rating Typically 0.125W to 0.25W Typically 0.1W
Best Used For Prototyping, hobbyist projects, learning SMD soldering. High-density layouts, compact wearable electronics.
Tips for Successful Manual SMD Soldering
Regardless of whether you choose 0805 or 0603, following a structured workflow makes manual assembly much smoother:
  • The “One-Pad” Method:
    1. Apply a small amount of solder to only one of the PCB pads first.
    2. Hold the component with tweezers, reheat that pad, and slide the component into place.
    3. Remove the heat, let it solidify, and then solder the second pad.
  • Use Plenty of Flux: External flux (tacky flux or a flux pen) is essential. It cleans the metal, helps heat transfer instantly, and prevents solder from bridging across tiny gaps.
  • Choose the Right Tip: Avoid ultra-sharp conical tips, as they do not transfer heat efficiently. A small chisel tip or hoof tip works best for transferring heat to both the pad and the component lead simultaneously.
  • Solder Wire Diameter: Use thin solder wire (e.g., 0.5mm / 0.020" or smaller). Standard through-hole solder wire is too thick and will deposit way too much solder onto small pads.
@jimMerk2
Why USA is clinging to FPS (Foot, Pound, Second) System while the originator of this system, England, themselves have abondoned this system and adopted MKS (Meter, Kilogram, Second) System decades ago?
And the funniest thing is that they call it Imperial system while they renounced the Imperialist rule of King of England on July 4, 1776, with the adoption of the Declaration of Independence.
:open_mouth: :wink:
Today only three countries of the world do not have metric system:
(1) United States (North America)
(2) Liberia (West Africa)
(3) Myanmar (South-East Asia)
GREEN = Metric (MKS) Sytem
RED = Imperial (FPS) System
The main advantage of metric system is that units and sub-units are mmultiple of 10, for example mm, cm, m, kM OR mg, g, kG) It makes it very easy to change from mm to m, simply move the location of decimal or kM to m add three zeros. The FPS lacks this ease.
As far as Farenheit and Centigrade is concerned, the main advantage of Centigrade is that it’s zero is not arbitrary like zero of Farenheit. The zero of Centigrade is the freezing point of Water. It is very helpful to visualize condition in locations like Canada where temprature falls below freezing: A glance at Minus degree Centigrade means below freezing point.
The global standard for Flight Levels (such as FL400 for 40,000 feet) using a unified barometric reference was developed by the International Civil Aviation Organization during the post-WW2 expansion of commercial jet aviation in the late 1950s and early 1960s.
The global standardization of Flight Levels using feet instead of meters was primarily driven by the United States and the United Kingdom, whose combined dominance in post-WW2 aviation shaped international policy. Please note that at that time, England was also using FPS system of measurements.
Timeline of UK’s Switching From FPS to MKS System of Measurements
  • 1965: The government officially announced a 10-year plan to adopt the metric system as the primary system of measurement for industry and commerce.
  • 1968: The Metrication Board was formed to guide industry and the public through the change (though it was later abolished in 1980).
  • 1973: Following entry into the European Economic Community (EEC), the UK adopted directives to label goods in metric units.
The only advantage of Farenheit is when you want to be “kind” to somebody when referring to his/her IQ as being equal to room temperature. Celsius is offensive.:rofl:
Standards and history are set/written by the “powers” of the day.
Back to the main off-topic. :upside_down_face:
@abcd567 I ordered those 3 combiners/splitters you posted about a few day ago. Let’s see how they perform.
Actually we abandoned the old MKS system decades ago and switched to SI in December 1965.
Also, it’s metre :wink:
A meter is a thing used to measure something.
Thanks for correction of spelling. However the spelling depends if it is referred to British English or American English. Please see detail below :
(1) Unit of Measurement:
The Metre is the standard spelling for the unit of length in British English,
The Meter is the standard spelling for the unit of length in American English
(2) Measuring Tools:
In both American and British English, a device used for measuring (such as a parking meter, water meter, or gas meter) is always spelled meter.
As far as I know, the SI units are specific to technical, scientific, & industrial matters, and for trade & commerce, the MKS system is in use since 1973 upon UK’s entry to European Economic Community EEC. Please correct me if I am wrong.
Yes, but as your original post referred to the use of the metric system in England I thought I should make a cheeky reference to the spelling as defined in the BSI standard. :slightly_smiling_face:
I remember when I was at school, prior to the UK’s entry to the EEC, we had a number of textbooks that referred to the MKS system and being told by our Physics master that they were incorrect and should refer to the SI system.
In practice it doesn’t make any difference in every day life as the units used are the same.
The information I have regarding the timeline is as follows:
Key Milestones in the UK’s SI Adoption
  • May 1965 (The Official Start): Following formal requests from the Federation of British Industries, the UK government officially agreed to a national policy of metrication. The British Standards Institution (BSI) published its first authoritative guide, The Use of SI Units, later that year.
  • 1968 (Education and Science): The Royal Society recommended that SI units be adopted exclusively in all scientific and technical journals. Around the same time, primary and secondary schools began shifting their curriculums to teach SI units as the primary system of measurement.
  • 1969 (The Metrication Board): The government established the UK Metrication Board to actively manage and coordinate the transition across different sectors of the economy.
  • 1973 (EEC Accession): When the UK joined the European Economic Community (EEC), it signed a treaty obliging it to formally incorporate SI-based metric units into domestic law for commercial and legal purposes
@LawrenceHill
To update my information about UK’s history of switching to SI units, I further explored the implementation of Metric System in UK through Google AI Gemini
My Question:
When SI was implemented in UK?
AI Response:
The implementation of the SI (metric) system in the UK did not happen overnight; rather, it was a gradual process that officially began in 1965.
Unlike many countries that switched rapidly through a single mandatory decree, the UK chose a sector-by-sector approach that took decades.
The Key Timeline of UK Metrication
  • 1897 (Early Legalization): The UK actually legalized the metric system for trade via the Weights and Measures Act 1897, but it was completely voluntary.
  • 1965 (The Official Start): The British government formally committed to adopting the metric system. This was prompted by British industries and manufacturing sectors who requested the change so they could remain competitive globally. The government set a 10-year target to fully convert the country.
  • 1969 (Medicine and Infrastructure): The metric system became mandatory for dispensing medical prescriptions. The UK Metrication Board was also established this year to coordinate industrial shifts.
  • 1973 (EEC Entry): When the UK joined the European Economic Community (EEC), it formally agreed to European directives to adopt the metric system across standard commerce.
  • 1974 (Education): British schools officially shifted to teaching SI units as the primary system of mathematics and science.
  • 1995 & 2000 (Trade Deadlines): Laws passed making metric units compulsory for packaged goods (1995) and loose goods sold in bulk (2000), such as meat and vegetables.
Why was it never “fully” completed?
The UK’s metrication program effectively stalled in the late 1970s and 1980s due to public pushback and shifting political priorities. In 1980, the Government abolished the Metrication Board, switching the remaining un-metricated areas back to a voluntary basis.
Because the process was frozen halfway through, the UK remains in its famous “dual-system” state today—using kilometers, grams, and liters for science and industry, but miles, yards, and pints for travel and pub culture.
If you would like to explore this history further, let me know if I should detail:
  • The political debate that led to the Metrication Board being shut down in 1980.
  • How the introduction of decimal currency in 1971 tied into this timeline.
Not really true.
The rules are published here if you’re really interested.
This is way off topic so I’ll finish here.
