How is distance calculated?
Tar1090 showed me more flights at around 90 nm, but graphs1090 states peak range as 65 nm how’s that possible? Opensky-networks showing a distance at 103 nm/191 km…
It’s by now an indoor setup obstructed by other buildings etc… Will need to get the antenna outside.
As far as i understand graphs1090 is calculating the peak average over the given time you’re looking at.
I’ve seen a similar behavior, but i decided to not care about these details.
Wise attitude. Makes life peaceful.
Well, the raw data should be the same i guess. It’s a really big difference. Does the messagerate, cpuload, etc. work i graphs1090. Or is it tar1090 that is wrong?
Peak should not be an avarage. Take a look, it draws a line where it peaked.
graphs1090 will only consider ADS-B aircraft.
Also it only checks once a minute.
That may be the reason… See the attached screenshots. Graphs1090 is set to 8 hours while taking the screenshot.
2020-05-10 12_31_32-graphs1090_ Performance Graphs
2020-05-10 12_31_05-Window
yeah that seems strange.
no clue what’s going on.
