Holding patterns
Where can i see aircraft in holding patterns on flightaware?
Honestly, unless there is some major event happening, like a TFR for the POTUS or a runway configuration change, the best place to look for holding patterns is in London, around EGLL. Every arrival into Heathrow ends at a holding pattern, as apparently they will send one aircraftat a time down the glideslope on their approach. So their holds are stacked as well, like a FIFO queue.
Also, they will not clear another aircraft to land until the previous arrival has cleared the runway, so you’ll see a lot of nice holds there.
Second place would be KLAS in a runway configuration change, as they have 4 different configurations they can use. Changing from one to another would require using the published holds on the RNAV and non-RNAV arrivals.
So try EGLL first, followed by KLAS (though check the METAR or ATIS for KLAS to see what they are using and when they might change).
BL.
Check for a yellow airport symbol: fly.faa.gov/flyfaa/usmap.jsp then zoom in on it here.
