The door is the air intake for the APU. The APU is basically a small turbine engine. (on some larger aircraft like the A380 pictured the APU engine is almost as large as some main engines in small aircraft. Some helicopters come to mind.)
The engines spin while on the ground when the wind passes through them. There is very little friction in the engines and they can start windmilling with just a few knots of wind.
do u mean by this that the spin of the engines on ground is not related with the apu ?
just wanna be sure …
He just meant that even when the APU isn’t running, a small gust of wind can start the inlet turbine spinning. Very noticeable when you’re standing next to a parked, unoccupied aircraft.
