FlightAware Discussions
Graphs1090 Reporting Gap
I have several RPis that all have this gap in cpu utilization near the same time every night. The system is not stopping and there are no gaps in ADS-B feeding.
cs2cpu
I have had another type of gap a few minutes ago.
The rate for aircraft seen dropped to zero for a few minutes, all other values/graphs were not impacted (beside the aircraft/message rate which is normal in this case).
Any ideas?
I determined that the reporting gaps were a side effect of a crontab sodtware update.
@wiedehopf can you confirm this?
What?
graphs1090 doesn’t come with an updater.
Don’t run the install/update script … gaps are unavoidable if you restart collectd.
The assumption from ua549 that it’s regarding cron.
I did not do anything on the device where the graph gap is shown at the given timeframe
I made a crontab entry to update the software periodically. When that happens there is a reporting gap.
Why? it’s done without crontab
Actually not all software is upgraded automatically without using crontab.
So how often do you have these gaps in one of the graphs …
I have no clue why it would happen, haven’t seen the issue.
Feel free to check the code yourself, i don’t care at all about this very very minor issue.
Less than once a week, so forget it
