I am running a 2.5 amp power supply with a pi 3 16 gig microsd card and a fa pro sick with a fa filter and a fa antenna
it all boots up and works good
then i get nothing after a while
so I manually reboot it from the fa website and all goes well foe a couple of hours
i have high speed internet and I am using the built in wifi on the pi 3
i am running 2.15 jessie latest one
[2016-04-23 23:41 PDT] mlat(1003): Reconnecting in 30.0 seconds
[2016-04-23 23:41 PDT] mlat(1003): Beast-format results connection with localhost:30104: [Errno 111] Connection refused
[2016-04-23 23:41 PDT] no ADS-B data program seen listening on port 30005 for 180 seconds, next check in 60s
[2016-04-23 23:41 PDT] mlat(1003): Connection to localhost:30005 lost: [Errno 111] Connection refused
[2016-04-23 23:42 PDT] 13181 msgs recv’d from dump1090 (31 in last 5m); 13165 msgs sent to FlightAware
[2016-04-23 23:42 PDT] mlat(1003): Connection to localhost:30005 lost: [Errno 111] Connection refused
[2016-04-23 23:42 PDT] mlat(1003): Reconnecting in 30.0 seconds
[2016-04-23 23:42 PDT] mlat(1003): Beast-format results connection with localhost:30104: [Errno 111] Connection refused
tech supp0rt is busy
I just want to get back to normal rock solid operations
tried that
tried going direct stick to pi using the usb ports
and using a 3 foot high quality usb extender cable to get the stick away from my monitors and stuff
still happens.
even tried a rtl.sdr stick with tcxo and still happens.
Have you tried using a different power supply yet? Many RPi issues are caused by bad, poor quality, or dying power supplies.
I had a issue where my RPi 2 model B would boot normally but not feed FA due to a dying power supply. The power supply was less then 30 days old. Since that issue I got a good quality RPi power supply and also added a powered USB hub for my dongle. I’ve had no issues for over a year now.
FYI, my dongle is mounted on my antenna mast just below the antenna and is connected to my RPi in my house using a 32 foot USB extension cable.
A majority of Raspberry Pi issues are related to power supplies and USB cables running from the power supply to the Pi.
Use a good, calibrated digital voltmeter and measure the voltage at the Raspberry Pi, such as GPIO pins 2 (+5) and 6 (ground) while the Pi and anything hooked up to it is running.
You should read at least 4.8 Volts. If you read below 4.8 Volts, you have a not-so-good power supply, or USB cables that introduce too much voltage drop.
I am using a new canakit 2.5 amp supply ( have 2 new ones )
I am always able to reboot the unit from the website and it works for 12 hours or so then blammo down it goes
then I reboot from the website and I am good for another 12 hours or so
It does not have any problems where there is a ton of air traffic only when there is none to very minimal traffic ( 4 to 6 am usually )
also the window where it shows the aircraft being heard on the right side sometimes fills up with data slowly ( false data ) for 5 or 10 seconds then it slowly boils down to what is actually out there.
I think that this might be a software issue ( i don’t know )
i also have connected the pro stick directly to the pi 3 with no usb cable and still have the same problems.
funny thing is you try to stay current and have something better where the older pi 2 unit with the older pi aware version was rock solid !!!
I also changed the mlat over to 30104 seems to have helped
Re: rebooting PI
I have changed Power supply, HUB, PI, SD, SDR and my PI is still rebooting.
Its rebooting because it was hanging which required me to do something, so
I added the internal watchdog. So instead of a hang I get a clean reboot.
The watchdog is doing a ping of its router every 3 seconds so if network
is broken I loose 4 pings an it reboots.
I’m not using wlan0, and I have 2 ethernets (1 internal, and 1 via USB)
The network gets wedged If I have internal, or external, or both running.
It reboots about once or twice a week unless I turn MLAT on. Then it
reboots a few times per day
Looking at the syslog I see that the PI did not
get any reply from pings. TCPDUMP on
another host shows no PING REQUEST.
Whats on the USB bus…
the SDR dongle
a USB->ethernet (second ethernet dongle)
I can remove the second ethernet (so i’m left
with just the onboard ethernet) and still get
the same problem (ie hang without watchdog,
and reboot if watchdog start).
PS I have run TCPDUMP (apt-get install tcpdump)
and when the problem occurs I no longer see
any ICMP ECHO REQUEST packets leaving the
PI.
PPS once the PI is hung (no watchdog) all I
see of a new incoming ssh is the first SEQ
packet. I don’t see the SEQ/ACK packet
sent from PI.
