# Gain Adjustment
**URL:** <https://discussions.flightaware.com/t/gain-adjustment/18376>\
**Category:** ADS-B Flight Tracking\
**Created:** [April 26, 2016, 5:27am UTC](https://discussions.flightaware.com/t/gain-adjustment/18376 "2016-04-26T05:27:33Z")\
**Posts on this page:** 1\
**Showing post:** 7
<div class="post-metadata">
**Author:** ![BartJr](https://sea1.discourse-cdn.com/flex019/user_avatar/discussions.flightaware.com/bartjr/32/33888_2.png) [@BartJr](https://discussions.flightaware.com/u/BartJr)\
**Post date:** [April 26, 2016, 4:03pm UTC](https://discussions.flightaware.com/t/gain-adjustment/18376/7 "2016-04-26T16:03:12Z")
</div>
> [@cptdevine](#):
> I’ve been wanting to setup a script to change the gain setting once every hour to test each setting and find the best results.
I wrote a script to sort of do this. I only ran for 15 second intervals because the amount of traffic can change a lot throughout the day. But you can try different durations.
It gives an output like:
```auto
test 1 of 10
gain= 49.6 messages= 771 positions= 41 planes= 49
gain= 48.0 messages= 742 positions= 43 planes= 51
gain= 44.5 messages= 785 positions= 37 planes= 51
gain= 40.2 messages= 677 positions= 35 planes= 51
gain= 37.2 messages= 743 positions= 32 planes= 48
gain= 32.8 messages= 711 positions= 37 planes= 46
test 2 of 10
gain= 49.6 messages= 667 positions= 32 planes= 44
test 10 of 10
gain= 49.6 messages= 757 positions= 43 planes= 49
gain= 48.0 messages= 814 positions= 37 planes= 51
gain= 44.5 messages= 830 positions= 37 planes= 50
gain= 40.2 messages= 766 positions= 49 planes= 43
gain= 37.2 messages= 671 positions= 31 planes= 50
gain= 32.8 messages= 651 positions= 27 planes= 43
===Totals===
Gain, Messages, Positions, Aircraft
49.6 6925 361 73
48.0 7230 331 76
44.5 7149 347 75
40.2 6883 352 71
37.2 7071 351 69
32.8 6653 332 69
Plotting the data into excel you can give helpful graphs
 ![](https://us1.discourse-cdn.com/flex019/uploads/flightaware/original/3X/2/2/2271abf6d9f8caf0740a4c82bb6b440c93ba6a85.png)
Although for tuning the Prostick it didn’t help me that much, since a lot of gains gave similar results ❓
 ![](https://us1.discourse-cdn.com/flex019/uploads/flightaware/original/3X/8/b/8b03798c68787b6594505a79cc2eb7372810a4f0.png)
Here’s the code. It’s pretty dumb (like it just waits 2 seconds after starting dump1090 rather than checking to see if dump1090 is actually ready). You probably want to change the measure\_duration, ntests, and gains variables at the top.
Stop any existing dump1090 process before running the script. **sudo /etc/init.d/fadump1090.sh stop** or \*\*sudo service dump1090-mutability stop
```auto
#!/usr/bin/python2
import time, socket, subprocess
measure_duration = 15 #seconds
ntests = 10 #Number of tests
mutability = False #set to True if you use dump1090-mutability
#gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6".split()
gains = "36.4 38.6 40.2 42.1 44.5 48.0 49.6".split()
#gains = "22.9 25.4 28.0 29.7 32.8 33.8 36.4".split()
gains.reverse()
results = {}
for i in range(ntests):
  print "test", i+1, "of", ntests
  for g in gains:
	if g not in results:
		results[g] = [0,0,{}] #msgs, positions, aircraft
	if mutability:
  	  p = subprocess.Popen(('/usr/bin/dump1090-mutability --net --gain '+g+' --oversample --fix --phase-enhance --quiet').split(),shell=False,stdout=subprocess.PIPE, stderr=subprocess.PIPE)
	else:
  	  p = subprocess.Popen(('/usr/bin/dump1090 --net --gain '+g+' --quiet').split(),shell=False,stdout=subprocess.PIPE, stderr=subprocess.PIPE)
	time.sleep(2)
	s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
	s.connect(('localhost',30003))
	t = time.time()
	d = ''
	while 1:
		d += s.recv(32)
		if time.time() - t > measure_duration:
			break
	s.close()
	p.terminate()
	messages = 0
	positions = 0
	planes = {}
	for l in d.split('
		a = l.split(',')
		messages += 1
		if len(a) > 4:
			if a[1] == '3':
				positions += 1
			planes[a[4]] = 1
	print "gain=",g, "messages=", messages, "positions=", positions, "planes=", len(planes.keys())
	results[g][0] += messages
	results[g][1] += positions
	for hex in planes.keys():
		results[g][2][hex] = 1
print "
===Totals==="
print "Gain, Messages, Positions, Aircraft"
for g in gains:
	(messages,positions,planes) = results[g]
	print g, messages, positions, len(planes.keys())
_[View the full topic](https://discussions.flightaware.com/t/gain-adjustment/18376)._
