[quote=“david.baker”]We are testing the update that should fix the range and midnight problem on the new FlightFeeder hardware.
We are sorry for all the problems and thanks for resetting your system when they go down.
I gave up resetting it every morning. I’m a pilot, I usually dont stay at home, and my wife started to complain when I asked her to reset the box every morning.
Then, the box will be offline until FA provides a solution.
I’m just beside of Congonhas Airport (SBSP), the busiest airport of Latin America, my receptor can receive all traffics on ground, and you are losing these (I think) worthy data.
Please let me know when a solution has been provided, then I will put it back online, so you can update the software.
If you give me permission, I would install a dump1090 or something like that on my Flightfeeder (on another SD card) to continue sending data to FA.
Let me monitor mine too by removing the 24hr timer which I make it off and on for 5 mins daily after midnight to temporarily resolve the midnight issue. Will update the team on status. BTW, mine is #1189.
Merry Christmas & Happy New Year 2015 Wishes to everyone.
Looks like the midnight bug which a number of us are facing seems rectified thru your software patch which you could have sent to out ADS-B online. So far after I have removed my manual 24hr timer which switch it off and on around midnight for 5 mins, for 2 days in a row left it permanently 24hrs ON, did not see any issues of not online. No more need to shutdown the system.
Congratulations on rectifying the midnight shutdown bug.
My flightfeeder stopped working last night. I had to reset it thru the power chord. It´s not freezing daily (or twice a day, as before), but it’s still not stable.
The receiver is frozen. I’ve received an email that my FlightFeeder is not sending data. You can try to check it now. I wont reset it until you ask me for it.
I received my feeder today and my excitement knew no bounds. However, after setting it up, it does nothing - i cant even access the internal management portal on port 8080. Does not send data, nothing on planeplotter either. Im on 5.9
My ff is acting strange since a few hours.
-my feed to fa only works for a few minutes
-virtual radar server sometimes gets 100 aircraft (one position), then a few minutes nothing, then 25 aircraft etc.
-its own web interface does not work.
-port 30002 sends out 1 message every few minutes
luckily the reboot button does work
i see others have version 5.9, is it normal that mine is still 5.5?
could someone look into this?
edit: strange that the ff seems to depend on fa’s website. website was slow and my ff stopped working…?? ff acts normal again, forum loads a lot faster now and no down messages any more.
or were the flightfeeders ddossing the site? LOL
Version 5.5 of the software is the latest version for the acrylic case version of the FlightFeeder.
Version 5.9 of the software is the latest version for the metal case version of the FlightFeeder.
Since the metal cases are using a different receiver if you install the version 5.9 of the software on an acrylic case it needs to be slightly modified to work with the older receiver.
