FlightFeeder on CuBoxi
Hello,
I have a CuBoxi from Solid-Run.com that can run Android. The device has Wi-Fi, Ethernet port and USB ports.
Does anybody tried to configure FlightFeeder with this device before? Any tips would be great if you have them.
Thank you…
solid-run.com/freescale-imx6-fam … ifications
You may be better off seeing if debian armhf will run on that rather than android; you should be able to use the raspbian piaware packages in theory.
Thanks for the reply. I will see if I can install the Debian. I did download FlightFeeder for Android and it is working. I have about 5 aircraft showing up on it. I believe a better antenna would have more aircraft show up.
