I received my first pro stick, and replaced the generic dvbt by pro stick.
I had to drop the gain of dump1090 from “max” to 35 dB for a meaningful performance, and now it is performing like the generic dvbt without any amplifier. I increased gain to 38 dB, and performance dropped.
Conclusion: For my location, with pro-stick, a filter is a must, but this is additional expenditure of $22, and eclipses the “value for money” charm of pro stick.
In past when I used a Satellite amplifier with the generic dvbt, and NO FILTER, It gave excellent results even at dump1090’s gain setting of “max”. I dropped gain to 44dB to reduce signals > -dBFS, but even then it gave excellent results.
The pro stick’s rf amplifier is very broad band (300 Mhz to 2400 Mhz) and amplifies all signals in this band which includes TV vhf/uhf, ham, walkie talkies, Cellular, WiFi & other communications like police, fire, taxi etc. This saturates the amplifier & tuner, and makes it essential to add a filter.
On the other hand the Satellite amplifier has a limited bandwidth of 950 Mhz to 2050 Mhz (L-band), which prevents amplification of signals of TV vhf/uhf, ham, walkie talkies, Cellular, WiFi & other communications like police, fire, taxi etc.
I suggest Flight Aware to use another rf pre-amplifier chip in next generation of pro stick, which should have narrower bandwidth (L-band).
I am now considering to solder 2 SMDs on the pcb strip connected to SMA connector centerwire. The other terminal of SMDs will be soldered to ground strip of pcb/SMA body.
SMD 1 = 22nH inuctor
SMD 2 = 1 pF capacitor
This will form a parellel resonant circuit (tank circuit as hams call it), resonantat 1075 Mhz. Since the Q factor of SMDs is generally low, it will not be sharply tuned at 1075 Mhz,but will have bandwith say ± 100 Mhz around 1075 Mhz. This should be sufficient to block TV & lower frequency cellular & other signals.
