Flightaware 7.x old Wi-Fi config
I recently upgraded to FlightAware 7.1 and lost the Wi-Fi that I had struggled to configure in 6.x. I wanted to post this to try and help folks that may be struggling with an older Raspberry Pi feeder like my B+ with an Asus USB-N10 Wi-Fi adapter with an r8712u chipset.
I unsuccessfully tried many times to configure the wifi using the wireless-XXXX configuration in /boot/piaware-config.txt, so I thought I would try and configure my old adapter with wpa_supplicant.
First, log in and:
sudo killall wpa_supplicant
Add a file /etc/wpa_supplicant/wpa_supplicant-wlan0.conf. Your interface may be different from mine, so replace wlan0 with your Wi-Fi interface name. Adjust the country to the two-letter country code and add your SSID and password, enclosing them in double-quotes
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=US
network={
	ssid="WIFISSID"
	psk="WIFIPASSWORD"
Once this is set, we’ll bring up wpa_supplicant to check if we can connect:
sudo wpa_supplicant -Dwext -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf -B
In my case, my Wi-Fi interface is wlan0, and it uses the wext interface for the older Wi-Fi drivers. You’ll probably have to adjust to get these working for your hardware.
Now, check to see if the interface comes up with:
ip addr show dev wlan0
If it has an IP address (configured via DHCP by default), you’re all set and you have it working. If not, double-check your interface(-i) and driver (-D) for wpa_supplicant.
To get it to start at boot, just enable it using systemd:
sudo systemctl enable wpa_supplicant@wlan0
Adjust the above command to use the interface name your adapter is using.
Now, reboot and see if your interface comes up automatically at boot.
Shawn
This is the default file to be created if using the script package on top of a Raspberry OS device.
Interesting that it’s working on the Piaware Image as well
The WiFi Country require to be set properly as well.
