Flight down in water off KMIA
#1
foxnews.com/story/0,2933,179168,00.html
Trying to get a tail number to match…
#2
My understanding is that the flight was operated VFR, so it likely isn’t on FlightAware.
#3
I heard the same…not that there would be much to see :frowning:
#4
The tail number is N130FS, but it wasn’t flying IFR under its tail number or under a company (CHK) callsign.
#5
Good find. I was rummaging around the site but couldn’t make any connection between any of the tail numbers and the plane that went down. Not sure if their site is just flooded w traffic or just natuarally slow. I’m leaning towards the former…
#6
Go to wsvn.com our local FOX affiliate. They have video coverage. You might also try local10.com and wfor.com and nbc6.net. Thiose are all of our Miami stations.
#7
The aviation incident report from the NWS says it is N2969
#8
:frowning:
http://www.airliners.net/open.file/923925/M/
http://www.airliners.net/open.file/480235/M/
#9
Curious, the FAA registry for N2969 says it has reciprocating engines, while the pictures Orlaam linked to show turbines. There are only two G73s registered with turbines, N2974 and N777PV.
#10
Retrofit perhaps?
#11
According to the people on Airliners.net, it was this plane: http://www.airliners.net/open.file/065216/L/
I haven’t looked or seen a 100% confirmation on the tail number. Airliners.net has some extensive discussion about it, but their forums have a lot of dead weight, so take it with a grain of salt.
Also, CNN has video of the plane going into the water. No doubt the people died from blunt trauma. Even if you didn’t die right away from the impact, you’d certainly be on borrowed time, especially trapped underwater. Very sad. Looks like the wing came off from the fire/explosion in the engine. The video is far from perfect though.
http://www.cnn.com/2005/US/12/19/miami.crash/index.html
#12
"Curious, the FAA registry for N2969 says it has reciprocating engines, while the pictures Orlaam linked to show turbines. "
My guess is that Orlaam has some bad info, I can’t recall ever seeing a NWS incident report that got the tail number wrong.
NOUS52 KMFL 192243
OAVMFL
AIRCRAFT INCIDENT MESSAGE
NATIONAL WEATHER SERVICE MIAMI FL
540 PM EST MON DEC 19 2005
TO: FORENSIC PROGRAM MANAGER (W/OS23)
C/O TELECOMMUNICATIONS GATEWAY
SUITLAND MARYLAND 20910
INFO… SOUTHERN REGION HEADQUARTERS…ATTN W/SR1X2
ALPHA…CHALK’S OCEAN AIRWAYS
FLIGHT NO. CHK101 (WATSON ISLAND TO BIMINI)
ACFT TYPE…G73T
REGISTRATION NUMBER…N2969
BRAVO…LOCATION…MIAMI BEACH, FL (GOVERNMENT CUT)
DATE…DECEMBER 19, 2005
TIME…241 PM EST (1941Z)…ESTIMATED
CHARLIE…AIRCRAFT CRASHED INTO THE WATER.
19 KNOWN FATALITIES. 19 PEOPLE ON BOARD.
17 PASSENGERS AND 2 CREW MEMBERS.
DELTA…MIA ASOS HOURLY OBS (UTC TIME)…
METAR KMIA 191953Z COR 32007KT 300V040 7SM OVC018
22/18 A3008 RMK AO2 SLP186 T02220183
METAR KMIA 191853Z 33008KT 4SM HZ OVC013 22/18 A3009
RMK AO2 SLP189 T02220183
            OPA LOCKA ASOS HOURLY OBS (UTC TIME)...
            METAR KOPF 191953Z 34008KT 10SM SCT012 BKN021 21/18
              A3008 RMK AO2 SLP184 T02110178
            METAR KOPF 191853Z 36010KT 10SM BKN010 OVC017 22/18
              A3009 RMK AO2 SLP188 T02170183
            MIA ASOS 5 MINUTES OBS (LOCAL STANDARD TIME)...
            12/19/05 14:10:31  5-MIN KMIA 191910Z 33006KT 4SM HZ OVC013
              22/18 A3009 -130 78 700 340/06 RMK AO2
            12/19/05 14:15:31  5-MIN KMIA 191915Z 35007KT 4SM HZ OVC013
              22/18 A3009 -130 78 700 360/07 RMK AO2
            12/19/05 14:20:31  5-MIN KMIA 191920Z 33007KT 4SM HZ OVC013
              22/18 A3008 -130 78 700 330/07 RMK AO2
            12/19/05 14:25:31  5-MIN KMIA 191925Z 34008KT 4SM HZ OVC013
              22/18 A3008 -130 78 700 350/08 RMK AO2
            12/19/05 14:30:31  5-MIN KMIA 191930Z 33008KT 4SM HZ OVC015
              22/18 A3008 -130 78 700 340/08 RMK AO2
            12/19/05 14:35:31  5-MIN KMIA 191935Z 33008KT 5SM HZ OVC014
            12/19/05 14:40:31  5-MIN KMIA 191940Z 33008KT 5SM HZ OVC014
              22/18 A3008 -130 78 700 330/08 RMK AO2
            12/19/05 14:45:31  5-MIN KMIA 191945Z 33006KT 5SM HZ OVC014
              22/18 A3008 -130 78 700 330/06 RMK AO2
            12/19/05 14:50:31  5-MIN KMIA 191950Z 34008KT 5SM HZ OVC018
              22/18 A3008 -130 78 700 340/08 RMK AO2 SLP186 T02220183
            12/19/05 14:55:31  5-MIN KMIA 191955Z 33006KT 10SM OVC018
            12/19/05 15:00:31  5-MIN KMIA 192000Z 34007KT 310V020 10SM
              OVC018 22/18 A3008 -130 78 700 340/07 320V030 RMK AO2
            12/19/05 15:05:31  5-MIN KMIA 192005Z 34006KT 10SM OVC018
              22/18 A3008 -130 78 700 340/06 RMK AO2
            12/19/05 15:10:31  5-MIN KMIA 192010Z 32007KT 10SM OVC018
              22/18 A3008 -130 75 700 330/07 RMK AO2
            OPA LOCKA ASOS 5 MINUTES OBS (LOCAL STANDARD TIME)...
            12/19/05 14:10:31  5-MIN KOPF 191910Z 35008KT 10SM SCT012
              OVC019 22/18 A3008 -130 81 600 350/08 RMK AO2
            12/19/05 14:15:31  5-MIN KOPF 191915Z 35009KT 10SM FEW012
              OVC019 22/18 A3008 -130 81 600 350/09 RMK AO2
            12/19/05 14:20:31  5-MIN KOPF 191920Z 35007KT 10SM FEW012
              OVC019 22/18 A3008 -130 81 600 350/07 RMK AO2
            12/19/05 14:25:31  5-MIN KOPF 191925Z 35007KT 10SM FEW012
              OVC019 22/18 A3008 -130 81 700 360/07 RMK AO2
            12/19/05 14:30:31  5-MIN KOPF 191930Z 34009KT 10SM FEW012
              OVC019 22/18 A3008 -130 81 700 350/09 RMK AO2
            12/19/05 14:35:31  5-MIN KOPF 191935Z 35008KT 10SM FEW012
              OVC021 22/18 A3008 -130 81 700 350/08 RMK AO2
            12/19/05 14:40:31  5-MIN KOPF 191940Z 34007KT 10SM FEW012
              OVC021 21/18 A3008 -130 84 600 340/07 RMK AO2
            12/19/05 14:45:31  5-MIN KOPF 191945Z 35008KT 10SM SCT012
              OVC021 21/18 A3008 -130 84 600 360/08 RMK AO2
            12/19/05 14:50:31  5-MIN KOPF 191950Z 35009KT 10SM SCT012
              BKN021 21/18 A3008 -130 84 600 360/09 RMK AO2 SLP185
              T02110183
            12/19/05 14:55:31  5-MIN KOPF 191955Z 35009KT 10SM SCT012
              BKN021 21/18 A3008 -130 81 600 360/09 RMK AO2
            12/19/05 15:00:31  5-MIN KOPF 192000Z 36009KT 10SM FEW012
            12/19/05 15:05:31  5-MIN KOPF 192005Z 33009KT 10SM FEW012
              BKN021 21/18 A3008 -130 81 600 330/09 RMK AO2
            12/19/05 15:10:31  5-MIN KOPF 192010Z 35009KT 10SM -RA
              SCT012 BKN023 21/18 A3008 -130 81 600 350/09 RMK AO2
              RAB10 P0000
ECHO… KMIA 191731Z 191818 35004KT 3SM BR OVC005
TEMPO 1821 1 1/2SM BR
FM2300 01005KT 5SM BR OVC015
FM0500 00000KT 5SM BR OVC009
FM1500 00000KT P6SM BKN015
            KMIA 191940Z 192018 35004KT 4SM BR OVC012
             FM2300 35005KT 5SM BR OVC015
FOXTROT… WINDS ALOFT BASED ON AIRCRAFT DATA FROM AROUND TIME OF
THE ACCIDENT:
SURFACE…33008 KT (ASOS)
1000 FT…34010 KT
2000 FT…31007 KT
3000 FT…28011 KT
GOLF… MIAS WA 192045
AIRMET SIERRA UPDT 4 FOR IFR VALID UNTIL 200300
AIRMET IFR…FL AND CSTL WTRS
FROM VRB TO 70ENE PBI TO 60ESE EYW TO 80WSW EYW TO
60WSW PIE TO VRB OCNL CIG BLW 010/VIS BLW 3SM PCPN/BR/FG.
CONDS CONTG BYD 03Z THRU 09Z.
MIAS WA 191445
AIRMET SIERRA UPDT 3 FOR IFR VALID UNTIL 192100
AIRMET IFR…SC GA FL AND CSTL WTRS FROM 30NW IRQ TO 90SSE
ILM TO 70ENE PBI TO 60ESE EYW TO 30WSW EYW TO 20SW CTY TO
30SSW CEW TO CEW TO 40NW TLH TO LGC TO 30NW IRQ OCNL CIG
BLW 010/VIS BLW 3SM PCPN/BR/FG. CONDS ENDG 18-21Z.
HOTEL… FLIGHT BRIEFING INFORMATION NOT AVAILABLE.
SANTOS, SCIENCE AND OPERATIONS OFFICER, NWS MIAMI WEATHER FORECAST OFFICE
#13
[]FAA Press Release ](http://by109fd.bay109.hotmail.msn.com/cgi-bin/getmsg?msg=4BC28872-5F07-4872-A975-5064450A9867&start=0&len=8238&imgsafe=n&curmbox=00000000-0000-0000-0000-000000000001&a=e5050bab20f7927d0d1a099959d0a8fcb8de6ed9630a5b720cdb5c0f62a86b0b)
[]FAA ](http://www.ntsb.gov/ntsb/brief.asp?ev_id=20060106X00018&key=1) Prelimary report [] N2969 ](http://www.airliners.net/open.file?id=0163313&size=L&width=900&height=612&sok=JURER%20%20(ert%20%3D%20'A2969')%20%20BEQRE%20OL%20cubgb_vq%20QRFP&photo_nr=6&prev_id=0373133&next_id=0120256) actual aircraft involved
