flight aware box
I have an FA dongle - the new blue one which works fine apart from I am getting errors on my account
Anomaly report for PiAware site 39170 - lynemouth:
This feeder is not being used for multilateration because its timing information appears to be unreliable. This can be caused by the site location being incorrect, or because your Pi is running out of free CPU.
I have to reboot the pi3 quite a few times so i suspect the pi3 is running out of cpu, however i don’t know how, its on 24/7 and feeding data but its only being used for that.
I have requested a flight aware box, if I’m not approved then are they available to buy, if so are they expensive as I’ve already laid quite a bit out to feed data.
Im in the UK
ps -ax , then post output.
I sorted it out, my location was set incorrectly (I set it manually by GPS) decided to use the configuration on the site where it brings up map etc. Now I’m getting no errors after reboot and
Supported / Enabled (synchronized with 70 nearby receivers) which i didn’t before.
Time will tell if my pi3 decides to play up but have checked the CPU levels and they seem ok.
Im only using the pi for feeding but it is 24/7
It’s not normal having to reboot, mine run easily for 200 days if power is not interrupted…
/M
