Feature request: RPi cpu temperature on dump1090 webpage
First post, so be gentle. I would like to see my Raspberry pi cpu tempersture displayed somewhere prominately on the 1090 dump webpage. I leave my monitor on that page and seldom change it. I would love to see the status of my cpu since the unit is located in an inaccesable place. I know the historical values of the cpu temperature and if i coud see the current temperature i could determine if my cooling fan has failed.
I never figured out how to do that on the 1090 page but I did manage to get Rpimonitor set up that has that info.
I found it in this thread:
and here is a screenshot
I have it on a seperate page for exactly that reason.
Hope this helps
You can get the temp with vcgencmd measure_temp.
Other useful vcgencmd actions are:
vcgencmd get_throttled
vcgencmd get_config int
vcgencmd measure_volts.
I run these commands from a terminal window.
I agree it would be great to see something similar to the status block that is displayed in pi-hole on either the dump1090 or the site information screen rather than having look at other screens to get the same info.
You can see the CPU temperature by visiting the PiAware Status page (enter the IP address of you piaware in a browser.
Unless you are talking about having it on the SkyAware map page…
hola tambien he buscado la forma de obtener esa informacion en una pagina de los mapas y no lo he conseguido solo regresando a la pagina de inicio como se muestra en la foto, quiero aprovechar para informar que desde hace 10 meses tenia problemas con mi feeder CPU RPi que se calentaba y se perdian los enlaces de internet,numero, wifi los tuneles de conduccion se bloqueaban etc, me cambie a PiAware y enseguida ese sofware me informo que la CPU estaba con temp de70 grados centigrados le coloque un disipador de calor forzado y ahora si esta trabajando normal, le recomiendo a los que fabrican es CPU RPi que le instalen un disipador de calor a los futuros CPU que sean destinados a lugares o paises de clima tropical calido, yo se que ellos saben de ese problema.
Translation
Hello, I have also looked for a way to obtain that information on a page of the maps and I have not achieved it just by returning to the home page as shown in the photo, I want to take the opportunity to report that for 10 months I had problems with my CPU feeder RPi that was heating up and the internet links were lost, number, wifi, the driving tunnels were blocked etc, I switched to PiAware and immediately that software informed me that the CPU was with a temperature of 70 degrees Celsius, I placed a forced heat sink and Now if it is working normally, I recommend to those who manufacture the RPi CPU that they install a heat sink to future CPUs that are destined for places or countries with a hot tropical climate, I know they know about this problem.
