Failure to upgrade to 11.0
Can anyone help?
I am trying to upgrade via the Flight Aware web portal, from 10.2 to 11.0.
2026-05-19 11:42 CDT] performing manual update, action: piaware
[2026-05-19 11:42 CDT] *** running command ‘/usr/lib/piaware/helpers/run-apt-get update’ and logging output
[2026-05-19 11:42 CDT] manual update (user-initiated via their flightaware control page) requested by adept server
[2026-05-19 11:42 CDT] run-apt-get(7132): Ign:1 http://www.flightaware.com/mirror/raspbian/raspbian buster InRelease
[2026-05-19 11:42 CDT] run-apt-get(7132): Err:4 http://www.flightaware.com/mirror/raspbian/raspbian buster Release
[2026-05-19 11:42 CDT] run-apt-get(7132): 404 Not Found [IP: 172.64.150.77 80]
[2026-05-19 11:42 CDT] run-apt-get(7132): Ign:2 https://apt.svc.flightaware.com/piaware/release buster InRelease
[2026-05-19 11:42 CDT] run-apt-get(7132): Hit:3 http://www.flightaware.com/mirror/raspberrypi/debian buster InRelease
[2026-05-19 11:42 CDT] run-apt-get(7132): Err:5 https://apt.svc.flightaware.com/piaware/release buster Release
[2026-05-19 11:42 CDT] run-apt-get(7132): 404 Not Found [IP: 172.64.148.77 443]
[2026-05-19 11:42 CDT] skipping action piaware
[2026-05-19 11:42 CDT] child process 7132 exited with status EXIT 100
[2026-05-19 11:42 CDT] update request complete
[2026-05-19 11:42 CDT] run-apt-get(7132): Reading package lists…
[2026-05-19 11:42 CDT] run-apt-get(7132): E: The repository ‘http://flightaware.com/adsb/piaware/files/packages buster Release’ no longer has a Release file.
[2026-05-19 11:42 CDT] run-apt-get(7132): E: The repository ‘http://flightaware.com/mirror/raspbian/raspbian buster Release’ no longer has a Release file.
You have old OS buster. Not sure if it is supported for ver 11.0.
Some one from Flightaware staff can give a valid answer.
For upgrade to 11.0 on Trixie, we are using the method in following post:
https://discussions.flightaware.com/t/install-piaware-on-debian-13-trixie/99296/39
Hi,
When I reviewed the changelog a few days ago, I noticed that when they added Trixie, they removed support for Buster. Suggest you just stick with what you have for now. Even if you could, I doubt you would notice any change between 10 and 11. It is mainly Trixie support.
Link to dump1090-fa changelog:
For you, don’t worry about 11 until you decide it is finally time to upgrade your entire system. That will be a fresh start from scratch. When you do that then, you will have the latest. There’s no rush.
Regards,
-Dan
Mine is running on bullseye without any problems. Probably not working on buster
From the changelog of dump1090:
  • Add build support for trixie, remove buster support
From the changelog:
“skyaware: Update aircraft database to 2026-04-09”
My first thought was this would apply to Skyaware Anywhere. Since it does not mention Anywhere, where is this database located?
Try in your Browser:
IP-of-Pi/skyaware978/data/aircraft.json
OK, it’s on the SD card. So unless/until I upgrade to version 11.0 I won’t have this updated database.
/usr/share/skyaware/html/db
Correct, 11.0 does not support buster, mostly because upstream OS support for buster has ended (Debian’s LTS support ended in mid-2024)
