While attempting to install the FR24 feeder to run alongside my PiAware, I’m getting an error
wget: invalid option – ‘0’
If anyone can offer me some help here it’d be much appreciated. (trying for three hours so far)
That’s an O the letter not a zero.
You have other typos in that command line.
Best to copy the command and use right click or middle click to paste the command in putty.
Also be sure to chose beast TCP as receiver. (host 127.0.0.1 port 30005)
Don’t chose DVB-T it will stop dump1090-fa working
Okay, thanks for the help! I’m in setup now, any idea what to do for
Please enter your receiver’s COM port number/device path
you chose wrong.
BEAST but TCP.
you can rerun the configuration using:
sudo fr24feed --reconfigure
so you press 4
then chose TCP.
I guess that is maybe called Network in that configuration interface? (TCP = network)
Sorry i mainly use the configuration file.
Yeah, it was network. Skipped right past it because I was looking for TCP
I appreciate your help.
Now I just gotta get FR24 figured out, lol.
What do you mean?
sudo systemctl restart fr24feed
Then after 20 min or so it should show them in your account:
Live Flight Tracker - Real-Time Flight Tracker Map | Flightradar24
You hopefully used the same Email address.
Go to this post, scroll down, and you will find settings for FR24 feeder also. It is an old post, but FR24 installation & settings are still valid
