We decided to move in a couple of weeks and there i have the opportunity to bring the antenna outdoor.
As i am not able to drill through the window frame or the wall, the Raspi and the stick needs to be outside too. electric power is given, connect will be WiFi
The balcony is 3/4 covered by the roof so water might not be the big issue. But the heat in summer times can cause some issues because i am expecting a slight heat congestion where i want to place the Raspi and the stick.
hello kenf3, it seems to me that if you added a second vent near the bottom of the front panel you could create a chimney effect and vent more heat out of the enclosure. by the way, the inside organization is impressive…nice work.
That one pressure vent in the upper center doesn’t allow free-flowing air since it’s designed to keep water out - it probably requires the same air pressure as inflating a balloon so adding a 2nd vent wouldn’t change things.
The circulation fan solved the +80’C cpu temp problem as I haven’t seen cpu temps over 65’C even when it’s sunny and 100’F (38’C) outside and with 2 tuners (1090 + 978).
