I already tried it, the same result. I don’t know what happened. The error message doesn’t give directions to solve the problem. I installed ubuntu from scratch two days ago and after that, I can’t instal dump1090exporter. In the older installation, it worked perfectly. I think something is missing in my environment but I don’t know what.
I had reinstalled aioprometheus but without any change. I rebooted the system, without any change too.
So I tried to reinstall only the component system. After that, I had that message:
I think there is another way to install dump1090 exporter but I can’t recall that way. I remember when I installed it and when it worked very well then the installation messages were different from installation messages from pip(3).
Is there anybody who installed that exporter by method another than by pip(3)?
@marekpow
I am running Dump1090exporter and it works nicely with Prometheus and Grafana right now.
How do you run dump1090exporter?
I need to config it run as a service, otherwise when you close your terminal it will shutdown.
