FlightAware Discussions
Dump1090 MySQL Database Script with Alert and Filter
Next try
After i updated the script with the isset part provided by @wiedehopf the script is running, i am getting datasets into the DB
But the script itself throws out an error right after i added the three lines:
PHP Notice: Undefined index: alert_max_alt in /home/pi/dumpsql/radar.php on line 192
It can be supressed by piping to /dev/nul, but i think the problem should be resolved.
You should resolve the problem by giving that variable a value.
It’s in line 16.
If you only want the database and no email alert set it to -5000.
Ah, that was my fault. I simply commented out the mailer/alert settings because i do not need them.
Thanks for the eye opener
Running out of SD card space… how do I archive the contents of the database? I have all the daily files.
Bumping this… Can someone help me dump the contents and clear the database? Running out of space on the SD card
check this pacge: https://www.mysqldumper.de/
German page but a great tool
To drop the tables you no longer want use drop table:
You can use mysqlworkbench if you want a graphical interface that will let you select multiple tables:
https://www.mysql.com/products/workbench/
I still want the table. Just need to clear it. I’m thinking, based off of what I read to truncate it?
truncate the table
mysql -u root -p
USE adsb;
truncate table aircrafts;
exit
Revisiting this as I really want to:
Write all flights from aircraft.json to my database AND send me an email on specific flights and/or HEX codes.
So for the above what must these settings be (I’ve figure all the others in the radar.php file):
set this to true if you want alerts and/or database writes from those aircrafts matching your hex_code_array.txt or flight_code_array.txt files within limited area or whole site-range, with or without wildcards
$user_set_array['filter_mode_alert'] = false;    $user_set_array['filter_mode_alert_limited'] = false;
$user_set_array['filter_mode_database'] = false;     $user_set_array['filter_mode_database_limited'] = false;
$user_set_array['filter_mode_wildcard'] = false;
It seems from my testing that I can’t have both options, all flights and emails on specific flights/HEX, is that true?
