@Arunchinna
The FC0012 is the worst offender. The various FC0013âs âmightâ be able to be modified to work at 1090. The table below is the âreceived wisdomâ and is reproduced in many places.
Some of the FC0013âs are claimed to have an L-Band input on the chip (allowing input up to 1700MHz), but as no second connector is provided, it would require internal modification.
Given the Fitipower chips all get poor reviews (high noise floor, poor sensitivity, synth spurs) and no datasheet seems to be available, I really canât see the point spending time on it.
Several of the people I have dealt with that unknowingly had a Fitipower chip did not intentionally purchase a Fitipower chip. The seller used standard online descriptions that identified it as a typical R820T or similar, and then shipped a Fitipower, often by mistake.
The bigger companies would not do this, but some of the smaller online resellers might not even fully understand the difference. Most just returned the device. Some asked the seller, who then immediately shipped out the correct device.
You probably need to be more specific in asking the question. You can actually ask AI to write code in a specific language. Also apparently copilot AI is better at answering these types of questions than google AI, although I havenât tried it.
If you mean itâs good at pasting together text without understanding any of it, maybe?
(for example, the âguaranteesâ part is a bunch of mostly-true statements slapped together but the explanation as a whole makes no sense â halfway through it starts talking about the uniqueness of syndromes for single-bit errors, which is entirely irrelevant in brute-force correction)
You are right. I have noted that answers / solutions by AI are often wrong, confusing or misguiding.
Google search AI collects bits and pieces from discussion forums, facebook, articles on web by novice & hobbyists etc and combine these and outputs the mixture..
While the suggested pseudo code is in some way correct. Nobody ever would do this. CRC obeys linearity, i.e, CRC(A x B) = CRC(A) x CRC(B). Flipping a single bit is M x (0..010âŚ0).
For ADS-B you are interested in the bit pattern 0..010âŚ0 for which you get:
CRC(M x (0..010..0)) = 0
which by linearity is
CRC(M) x CRC(0..010..0) = 0
which then yields
CRC(M) = CRC(0..010..0)
So you precompute all CRC(0..010..0) and put them in a hashtable
If you have message M with CRC(M) != 0, look into the table at CRC(M) to get your bit correction pattern.
