Having problems. Installed MM2 and uninstalled it as wells described by ABCD567.
But now my dump1090-fa is not working and also Mlat is not enabled.
Could some one please help me?
4de7584…2db85c3 master → origin/master (forced update)
HEAD is now at 2db85c3 db update
remote: Enumerating objects: 191, done.
remote: Counting objects: 100% (191/191), done.
remote: Compressing objects: 100% (61/61), done.
remote: Total 176 (delta 134), reused 157 (delta 115), pack-reused 0
Receiving objects: 100% (176/176), 125.57 KiB | 824.00 KiB/s, done.
Resolving deltas: 100% (134/134), completed with 15 local objects.
From GitHub - wiedehopf/tar1090: Provides an improved webinterface for use with ADS-B decoders readsb / dump1090-fa
branch master → FETCH_HEAD
50ec99d…fea4e71 master → origin/master
HEAD is now at fea4e71 shuffle js loading order
FATAL: could not find aircraft.json in any of the usual places!
checked these: /run/readsb /run/dump1090-fa /run/dump1090 /run/dump1090-mutability /run/adsbexchange-feed /run/skyaware978
The instruction to Uninstall modesmixer2 at Github are as follows. These in no way can interfere or affect dump1990-fa, unless in these commands you have used dump1090-fa in place of mm2 and modesmixer2.
UNINSTALL
To completely remove configuration and all files, give following 5 commands:
sudo systemctl stop mm2
sudo systemctl disable mm2
sudo rm /lib/systemd/system/mm2.service
sudo rm -rf /usr/share/mm2
sudo rm /usr/bin/modesmixer2
checked ««49.6
40# dump1090-fa configuration
# This is sourced by /usr/share/dump1090-fa/start-dump1090-fa as a
# shellscript fragment.
# If you are using a PiAware sdcard image, this config file is regenerated
# on boot based on the contents of piaware-config.txt; any changes made to this
# file will be lost.
# dump1090-fa won't automatically start unless ENABLED=yes
ENABLED=yes
RECEIVER_OPTIONS="--device-index 0 --gain 49.6 --ppm 0 --net-bo-port 30005"
DECODER_OPTIONS="--lat 52.509058 --lon 6.110759 --max-range 360 --fix"
NET_OPTIONS="--net --net-heartbeat 60 --net-ro-size 1300 --net-ro-interval 0.2 $
JSON_OPTIONS="--json-location-accuracy 1"
Also
pi@raspberrypi:~ $ sudo systemctl status dump1090-fa
Warning: The unit file, source configuration file or drop-ins of dump1090-fa.ser
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled; vendor pres
Drop-In: /etc/systemd/system/dump1090-fa.service.d
└─bias-t.conf
Active: activating (auto-restart) (Result: exit-code) since Tue 2020-12-08 12
Process: 3950 ExecStartPre=/home/pi/rtl_biast/build/src/rtl_biast -b 1 (code=e
Process: 3955 ExecStart=/usr/share/dump1090-fa/start-dump1090-fa --write-json
Main PID: 3955 (code=exited, status=1/FAILURE)
lines 1-10/10 (END)
ec 08 13:46:14 raspberrypi dump1090-fa[27265]: Found 1 device(s):
Dec 08 13:46:14 raspberrypi dump1090-fa[27265]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Dec 08 13:46:14 raspberrypi dump1090-fa[27265]: Using device 0: Generic RTL2832U OEM
Dec 08 13:46:14 raspberrypi dump1090-fa[27265]: Found Rafael Micro R820T tuner
Dec 08 13:46:17 raspberrypi systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Dec 08 13:46:17 raspberrypi dump1090-fa[27270]: /usr/share/dump1090-fa/start-dump1090-fa: 1: /etc/default/dump1090-fa: ««49.6: not found
Dec 08 13:46:17 raspberrypi dump1090-fa[27270]: /usr/share/dump1090-fa/start-dump1090-fa: 2: /etc/default/dump1090-fa: 40#: not found
Dec 08 13:46:17 raspberrypi dump1090-fa[27270]: Tue Dec 8 13:46:17 2020 GMT dump1090-fa 4.0 starting up.
Dec 08 13:46:17 raspberrypi dump1090-fa[27270]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000001)
Dec 08 13:46:18 raspberrypi dump1090-fa[27270]: Found Rafael Micro R820T tuner
Dec 08 13:46:18 raspberrypi dump1090-fa[27270]: rtlsdr: tuner gain set to 49.6 dB
Dec 08 13:46:18 raspberrypi dump1090-fa[27270]: Error opening the listening port 30104 (Beast TCP input): bind: Address already in use
Dec 08 13:46:18 raspberrypi systemd[1]: **dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE**
Dec 08 13:46:18 raspberrypi systemd[1]: **dump1090-fa.service: Failed with result 'exit-code'.**
««49.6
ENABLED=yes
[ Read 16 lines ]
remove the first line completely and the 40 in front of # in second line. These are the previous errors due to misconfiguration.
The config file should start with
However that won’t fix the port issue.
For this specific topic it is required to know what is running on port 30104
ENABLED=yes
ENABLED=yes
