It seems not to work with me. I can see it get’s plane data because I can see in the page title that it display’s for example 20/60
But only a black screen. What am I missing here ?
i’ll send you PM to help
Edit:
@bramjacobse
Thanks for you’re help, It is working now
http://emiel1234.ddns.net/3d/
How do I enter both both www.ok1slm.cz and 192.168.0.24 to both work?
I’m sure this can be done in sort of a way.
However my programming skills don’t go far enough.
I use a script from noip.com wich wil get the external IP from the Rpi and links this to emiel1234.ddns.net
The router/modem wil automaticly convert this to internal as long as I forward the correct ports.
But I know not every router/modem will do this.
I think the solution is to check router settings first.
You have a domain linked to you’re external IP so the problem is you’re router has to recognize to internally forward that to the local IP.
Some routers block that.
Maybe it can help if you give the brand/type of you’re modem/router you are using?
This is the modem that was taken over by a cable company Hitron cve-30360
Thinkered 3D Viewer
works with latest 3.6.2 and dump1090-fa .
http://www.bramjacobse.nl/show/3d.zip
edit settings in the “index.html” add
var BingMapsAPIKey = 'xxxxxxxxx';
var myLat = xx.xx;
var myLon = xx.xx;
// Default camera position (play and space key press)
var camLat = xx.xx;
var camLon = xx.xx;
var hostIp = 'http://xx.xx.xx.xx'; // example 'http://192.168.1.200'
var dumpPort = 80; // dump1090 port number
var pfPort = 30053; // planefinder port number
Regards Bram
I’m not sure since I’m not familiar with that type router.
You could try changing the DNS settings, Further I can not find a lot more on this router.
(doubt if this will work btw)
Try the DNS from google
8.8.8.8
8.8.4.4
http://setuprouter.com/router/hitron-technologies/cve-30360/dns.htm
same problem, i only can see numbers of aircrafts xx/xx and only map.
did you edit the variables in the index.html file…?
You have to put in Bing Key.
And your LAT and LON coordinates
var BingMapsAPIKey = ‘xxxxxxxxxxxx’;
var myLat = xxx.xx;
var myLon = xxx.xxx;
var camLat = xx.xx;
var camLon = xx.xxx;
var hostIp = ‘http://xx.xx.xx.xx; // example ‘http://192.168.1.200’
hostip = ip adres of your raspberry running dump1090-fa
yeah BingMapAPI, lat/long, hostIP, etc everything is set correctly sir. Still only showing amount of aircraft.
Clear browser cache and force reload website , and if its still won’t work.
check Java script console in browser and check for errors
The script shoul’d be working
I made a mistake with long/lat coordinates. Make sure they are ok
