Hi, my system is getting better all the time.
From a basic RTL dongle using diy antenna to the full setup using Prostick+ and 1090 antenna, things are so much better, and having moved the antenna again as a last resort, the improvement is even better, but I’m at the limit of what I can capture due to my location and natural screening, but this is not my problem?
Ive just noticed that my PiAware 3.8.1 setup using RP4 is now displaying two IP addresses, showing this setup connected to Wireless & LAN.
I’d prefer to use LAN and have been doing so to-date, and when I plug in the ethernet cable, wireless would disable, reported on screen, however not the case just now.
I managed to enter the config.txt file on the MSDC and removed my SSD user and password, yet it still shows two IP addresses when I restart the system, and I have also rebooted the router.
I know next to nothing when it comes to editing software, but have returned the config.txt too as it was before, in the hope that someone here can explain in simple speak, what is wrong if at all it is wrong?
So, Used to cut off when LAN connected, now it has dual IP address and wireless stays on with LAN connected!
You should activate SSH so you don’t need the keyboard.
I’m also using a RPI4 and in the piaware-config.txt file I have the following: rfkill yes wireless-network no
If I’m not wrong, “rfkill yes”, will put RPI4 in airplane mode, turning off wifi and bluetooth, “wireless-network no” will disable wireless network (probably irrelevant because it’s in airplane mode).
I’m also expecting the rfkill will also lower the RPI4 power needs.
I did set wireless to ‘no’, even removed password and user name but it still displayed both IP addresses.
I’m completely alien to Linux, Raspberry, PiAware, but all this information is helping more than you realise.
I’m enjoying the Pi4 setup with its ‘little’ ice tower compared to my heavy lumbering old PC setup, but need to learn more about the software and programming.
There is a bug in the currently released version where where if you had a valid wireless config in the past, then later change to wireless=no, the originally generated wireless configuration files will not be removed so the old config will persist.
Try removing /etc/wpa_supplicant/wpa_supplicant.conf and rebooting:
sudo rm /etc/wpa_supplicant/wpa_supplicant.conf
(be careful with that command, sudo rm can do a lot of damage if pointed at the wrong place…)
That said, unless you have particular reasons to want to disable wifi, it’s mostly harmless to have both wifi and wired interfaces up at the same time - as mentioned above they have different metrics, so the wired interface will be used in preference if both are available.
While I was an officer in the USAF around 1991, we had a young airman working on Sun 3 computer with UNIX. He had read the books and knew everything, just like we all did when we started working with computers. Anyway, he was running out of disk space as his logs were getting full, and figured he could use abcd567’s command above to clean up a few files. And as you already know, he figured out it was not a good command to use, and then had to learn how to fully install the operating system from scratch. Good learning experience. I spoke with an old UNIX guru and he laughed about this happening to all new people. This was designed into UNIX from the beginning. The initial developer knew people would try to see if they could mess up the system, so he made it easy. Peer pressure from others affected by the trashed system forced the new people to learn from the experience. I think he was insightful. And yes, I did this to one of my own systems too. I have always learned much more about how things work by doing making stupid mistakes and then having to fix the same.
Great, having really changed nothing my end, I was hoping someone would say something similar that there’s an issue with an update!
Thank you everyone for your input so far. I’m gonna get me another micro sd card, install the full Raspberry software, and proper read the manual, so I’ve got a better understanding of what I can and shouldn’t do with Linux.
