TomMuc
October 31, 2020, 4:53pm
1
hi,
just two short question cause i’m too lazy tonight for wireshark:
thanx
tom
I don’t think so. For sending data you will need piaware as well.
Settings are made in the config under /etc/default
obj
October 31, 2020, 5:23pm
3
No. (Other than the obvious thing that when you fetch the packages, that request ends up in our web logs)
TomMuc:
where are settings made without piaware?
/etc/default/dump1090-fa
TomMuc
October 31, 2020, 6:06pm
4
@foxhunter @obj
thanx guys for superfast help + have a nice weekend despite all this covid19 trouble
cheers
tom
Just curious - Whats the problem with the “possible” dialing home? Since you ask here, I guess you already feeding.
TomMuc
October 31, 2020, 7:16pm
6
is there a description/list of all possible config params/values for dump1090-fa anywhere?
Have you tried dump1090-fa --help?
Apart from that, the source code.
Anything in particular you’re looking for?
TomMuc
October 31, 2020, 8:00pm
8
no. yes - my brain. thanx!
Hey @TomMuc , glad to see you after a long gap. Welcome back!
Reminds me of your following how-to’s
TomMuc
October 31, 2020, 8:41pm
10
hi abcd567. thank you. yes - once upon a time. good to see you still here - the good soul of the fa forum!
have a good one!
cheers
tom
TomMuc:
no.
Just in case you’re looking for some esoteric functionality like a TCP connect functionality, try one of the readsb flavors:
GitHub - Mictronics/readsb: Readsb is a Mode-S/ADSB/TIS decoder for RTLSDR, BladeRF, Modes-Beast and GNS5894 devices.
GitHub - wiedehopf/readsb: ADS-B decoder swiss knife (caution, bleeding edge segfaults (they tend to get fixed pretty fast, usually before i push to github))
Mine also has a TCP json output that will send out the state of an aircraft when a new position for that aircraft arrives with some minimum and maximum interval settings.
Some rudimentary SBS input (will not be output via beast/AVR only as SBS again, so not a converter).
TomMuc
October 31, 2020, 10:57pm
12
hi wiedehopf,
nope - i just wanted to make a super simple setup for home use.
but thanks for the links anyways! i’ll have a look at it and i have already seen that you have created a lot of good stuff here and on github over the last years.
cheers
tom
TomMuc
November 1, 2020, 6:12pm
13
well done the new 4.0 map interface.
system
Closed
November 1, 2021, 6:13pm
14
