I got a notice that my feed was not being received, so I checked on my feeder, which is a RPI Zero. There was no LED light. So I unplugged it and plugged it back in. It seemed to boot, and the LED glowed green, but it’s not connecting to the WIFI. I have two feeders. The other one is connecting fine. I cannot ping the failed one, and it doesn’t appear on my router network.
I looked at the SD card, and it seems to be fine, with configuration as it should be. I looked for logs but I don’t know where to find them when looking at the SD card.
I suppose I should have had a backup RPI Zero in case something failed. Is there something else I can check? The log as viewed from flightaware shows no anomalies other than it’s not connected. It has the last normal update showing in the actual log.
So I got a new RPI 4, and inserted the SD from the RPI Zero in it, and it doesn’t connec to wifi either, so I’m guessing the SD card got corrupted somehow. Now I’m trying to figure out how to flash the image. I’m guessing Piaware 10 from last year is the latest? Here’s what disk manager has for the volume that appears when I insert the SD card.
Apparently it was the SD card that went bad, but now I’m using an RPI4 instead of RPI zero, using a new SD card. I was unable to even format the old SD card (got messages stating it needed to be a writable card - I tried all the various things to make it writable and no-go, so I got a new card). Looks like it’s working now. And as to my latest request, I realized I should go to the main page instead of looking in the discussion group. I found the instructions I needed there. And it seems to be 11.1 instead of 10.
I have more work to do, including setting up SSH, and adding the other feeds I was contributing to.
I do have another question, though. I’ve claimed the feeder (it shows as a new feeder). If possible, I’d like it to continue where the other feeder left off. The old feeder is 24859. The new feeder (same antenna) is 286533. Is there any way to merge the two? They’re really the same feeder, I just replaced the RPI and SD card.
So a prerequisite, then, is to set up SSH. I thought to copy the bottom couple of lines that has that ID from the old file to the new file, but the feeder didn’t seem to be working when I did that, so I deleted those lines.
The antenna elevation is not setting. I thought I set it in the config file, but even if it had been set there, I tried updating it online, and whatever I enter there doesn’t get saved. OK. Maybe I just had to wait for some cycle. It’s updated now. Or I just needed to wait until I had posted about it, heheh.
