Delays leading to cancellations + follow-up
I am curious what happens to delayed flights. Some of these flights get cancelled and then some of these flights get replaced by another flight.
  1. Is there any way to see a list of delayed flights? I am looking for something with the same format as http://flightaware.com/live/fleet/UAL/cancelled
  2. Some cancelled flights show times in red - does this correspond to the time at which the flight was cancelled?
  3. Some airlines seem to use replacement flight numbers to catch-up on cancelled flights e.g. http://flightaware.com/live/flight/UAL1756 . Note that in this case the flight number appears to be used for any sector and any aircraft. Is there a way to identify these (random) replacement flights?
Is there and easy way to assemble the whole chain of delay/cancellation/replacement?
Steve
UAL1756 seems to a charter, not a ferry or sort…
UAL1756 is an extra section.
All UAL flights with 17XX flight numbers are extra sections.
But to your question, there is no easy way to assemble it because the process behind it is extremely complex. To re-assemble that process with secondary information after the fact is even harder.
Do you have an example?
Each airline will have a different number range they use for extra sections.
Not quite, of 1700-1799 only 1745-1764 are extra sections. Below that are scheduled flights, above that are ExpressJet charters and positioning for charters.
