New to Flight aware. Trying to get connected. No success. Have imaged sd card twice and followed al directions. Support is scarce! Directions indicated that a series of colored led lights would flash on raspberry . Only see green and scarcely flickers on staro up then is solid green. This is wireless connection with out door antenna . The claiming process seems a bit sketchy. Any help would be great. Thanks1
What hardware are you using?
What image are you using?
What is the behaviour you see? What is the behaviour you expected to see?
Be sure you have a proper power supply. Your problem suspiciously sounds like a power problem. Telling us the hardware and software you’re using will help us determine what light patterns you should be seeing.
Are you using a Raspberry PI that supports wireless? If so does your router show a connection established with the Raspberry PI? Solid green light sounds like it booted. What can you tell us about your config file? Have you added the proper lines for the wireless network with the password etc.?
