Connect to Alteryx?
Hi! Curious if anyone has used the FlightAware API to use in an Alteryx workflow?
(I’m working on a workflow that needs to tap into FlightAware and pull some flight data, for example if there was a delay, or the time of actual departure…)
Thanks!
KG
Hello,
I am not all too familiar with Alteryx, but AeroAPI delivers its data in JSON format and Alteryx appears to have the tools to work with that (as shown below). It would be up to the end user to figure out that bridge between the two.
As for what kind of data you would be able to pull, I would recommend checking out our full documentation for AeroAPI linked below. You won’t be able to get delay times (it would need to be calculated from the data provided), but you would be able to get actual departure.
https://flightaware.com/commercial/aeroapi/explorer/
Best regards,
Taylor Fischer -
Commercial Support
Toll Free: +1.800.713.8570
Support Line:+1.713.588.6514
Eleven Greenway Plaza, Suite 2900 - Houston, Texas - 70046
FlightAware
Learn about FlightAware Global and Premium Accounts: Commercial Services - FlightAware
