root@piaware:/# piaware -debug
2024-10-02 02:19:03Z ****************************************************
2024-10-02 02:19:03Z piaware version 9.0.1 is running, process ID 1598
2024-10-02 02:19:03Z your system info is: Linux piaware 6.6.51+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt2 (2024-10-01) aarch64 GNU/Linux
2024-10-02 02:19:03Z GPS: ::gpsdClient0: connect_completed
2024-10-02 02:19:03Z GPS: ::gpsdClient0: connection to gpsd at localhost/2947 failed: connection refused
2024-10-02 02:19:03Z GPS: ::gpsdClient0: closing gpsd socket, scheduling reconnect
2024-10-02 02:19:04Z Connecting to FlightAware adept server at piaware.flightaware.com/1200
2024-10-02 02:19:04Z Connection with adept server at piaware.flightaware.com/1200 established
2024-10-02 02:19:05Z TLS verify failed: certificate has expired
2024-10-02 02:19:05Z Failing certificate:
2024-10-02 02:19:05Z sha1_hash: DA1AE49EC2E57B0B412AEEDBFA3F89F558F98F34
2024-10-02 02:19:05Z subject: CN=*.flightaware.com,OU=Operations,O=FlightAware LLC,L=Houston,ST=Texas,C=US
2024-10-02 02:19:05Z issuer: CN=FlightAware Intermediate,OU=Operations,O=FlightAware LLC,ST=TX,C=US
2024-10-02 02:19:05Z notBefore: Sep 1 00:00:00 2018 GMT
2024-10-02 02:19:05Z notAfter: Oct 2 00:23:26 2024 GMT
2024-10-02 02:19:05Z serial: 204D
2024-10-02 02:19:05Z certificate: -----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
2024-10-02 02:19:05Z TLS alert (write): certificate expired
2024-10-02 02:19:05Z TLS error: certificate verify failed
2024-10-02 02:19:05Z TLS handshake with adept server at piaware.flightaware.com/1200 failed: handshake failed: certificate verify failed
2024-10-02 02:19:05Z reconnecting in 6 seconds…
2024-10-02 02:19:06Z ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
2024-10-02 02:19:06Z Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout
2024-10-02 02:19:06Z Started faup1090 (pid 1602) to connect to dump1090-fa
2024-10-02 02:19:06Z UAT support disabled by local configuration setting: uat-receiver-type
2024-10-02 02:19:06Z piaware received a message from dump1090-fa!
^C2024-10-02 02:19:09Z piaware (process 1598) is shutting down because it received a shutdown signal (SIGINT) from the system…
2024-10-02 02:19:09Z faup1090 exited with SIG SIGINT
2024-10-02 02:19:09Z piaware (process 1598) is exiting…
If this is true, where and how do I install the new certs?
Thanks Isaac
