Somehow I’ve managed to get my rPi into a state where the current flightaware install 3.5.3, won’t upgrade to 3.6.2. Here is what happens when I try it:
pi@piaware:~$ sudo dpkg -i piaware-repository_3.6.2_all.deb
(Reading database … 25285 files and directories currently installed.)
Preparing to unpack piaware-repository_3.6.2_all.deb …
Unpacking piaware-repository (3.6.2) over (3.6.2) …
Setting up piaware-repository (3.6.2) …
pi@piaware:~$ sudo apt-get install piaware
Reading package lists… Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these:
piaware : Depends: libreadline7 (>= 7.0~beta) but it is not installable
Depends: libssl1.1 (>= 1.1.0) but it is not installable
piaware-release : Depends: piaware-repository (= 3.6.2~bpo8+1) but 3.6.2 is to be installed
Depends: piaware-support (= 3.6.2~bpo8+1) but 3.5.3 is to be installed
Depends: piaware (= 3.6.2~bpo8+1) but 3.6.2 is to be installed
Depends: beast-splitter (= 3.6.1~bpo8+1) but 3.5.0 is to be installed
Depends: dump1090-fa (= 3.6.2~bpo8+1) but 3.5.3 is to be installed
Depends: piaware-web (= 3.6.1~bpo8+1) but 3.5.0 is to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
pi@piaware:~$
Trying the suggestion of apt-get -f install produces this result:
pi@piaware:~$ sudo apt-get -f install
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
atmel-firmware beast-splitter crda dump1090-fa firmware-atheros
firmware-brcm80211 firmware-intelwimax firmware-iwlwifi firmware-libertas
firmware-ralink firmware-realtek firmware-ti-connectivity firmware-zd1211
fontconfig ifplugd itcl3 iw libbladerf-udev libbladerf1
libboost-program-options1.55.0 libboost-regex1.55.0 libboost-system1.55.0
libdatrie1 libdrm2 libertas-firmware libfam0 libgraphite2-3 libharfbuzz0b
libiw30 libnl-3-200 libnl-genl-3-200 libpango-1.0-0 libpangocairo-1.0-0
libpangoft2-1.0-0 libplymouth4 librtlsdr0 libtcl8.6 libthai-data libthai0
lighttpd mime-support nano netcat-openbsd piaware piaware-support
piaware-web plymouth plymouth-themes rfkill rtl-sdr socat tcl tcl-tls tcl8.6
tcllib tclx8.4 usbutils wireless-regdb wireless-tools wpasupplicant
Use ‘apt-get autoremove’ to remove them.
The following packages will be REMOVED:
piaware-release
0 upgraded, 0 newly installed, 1 to remove and 58 not upgraded.
2 not fully installed or removed.
E: Can’t find a source to download version ‘3.5.3’ of ‘piaware:armhf’
I’m fairly new to the whole unix & flightaware stuff so I’m at a loss as to what is missing or how to resolve it. My system is working well on 3.5.3 so its not a pressing issue. I’d just like to keep up with the current version.
