I switched from my Raspberry Pi B+ and installed the Piaware iso on an older model B so I could use the B+ for something else. I have the new install updated and piaware is running, but dump 1090 fails to produce data on either port. I am also unable to connect to the piaware:8080 webpage. This is the output of piaware-status:
pi@piaware ~ $ sudo piaware-status
dump1090 is running.
faup1090 is not running.
piaware is running.
dump1090 is listening for connections on port 30005.
dump1090 is listening for connections on port 10001.
piaware is connected to port 10001.
dump1090 is NOT producing data on port 30005.
dump1090 is NOT producing data on port 10001.
I have previously used this same Pi with Piaware and the claim your pi page shows the previous claim but nothing new. I have used piaware-config to add my username and password. I’m at a loss to this and wondered if anyone had any suggestions.
This was a new install wasn’t it - you didn’t just pop the microSD card from the B+ in a SD holder and use it in the PI … becuase that won’t work due to the network interface on the two Pi’s not being identical and would need some additional work.
Thanks! The odd thing is, the B+ that runs Piaware perfectly also does not have that page. It has the page on :8080 but that’s it. In both cases, these are stock installs of the piaware iso I downloaded from here, so no idea why this is happening.
