Example Streaming
Streaming with socat:
rtl_adsb | socat -u - TCP4:sdrsharp.com:47806
Streaming details (see last few lines)
pi@raspberrypi:~ $ sudo apt install rtl-sdr
pi@raspberrypi:~ $ rtl_adsb --help
rtl_adsb: invalid option -- '-'
rtl_adsb, a simple ADS-B decoder
Use: rtl_adsb [-R] [-g gain] [-p ppm] [output file]
[-d device_index (default: 0)]
[-V verbove output (default: off)]
[-S show short frames (default: off)]
[-Q quality (0: no sanity checks, 0.5: half bit, 1: one bit (default), 2: two bits)]
[-e allowed_errors (default: 5)]
[-g tuner_gain (default: automatic)]
[-p ppm_error (default: 0)]
[-T enable bias-T on GPIO PIN 0 (works for rtl-sdr.com v3 dongles)]
filename (a '-' dumps samples to stdout)
(omitting the filename also uses stdout)
Streaming with netcat:
rtl_adsb | netcat -lp 8080
while true; do rtl_adsb | nc -lp 8080; done
Direct display of decoded signal
pi@raspberrypi:~ $ sudo systemctl stop piaware dump1090-fa
Found 1 device(s):
0: Realtek, RTL2832U, SN: 00000101
Tuner gain set to automatic.
Tuned to 1090000000 Hz.
Exact sample rate is: 2000000.052982 Hz
Sampling at 2000000 S/s.
Allocating 12 zero-copy buffers
*de12e7146d59403fe110003802d5;
*992ce5df5aa1086f42cc3630643a;
*8d4951745895c53f5c139b0cc045;
*8da0f86b58a703a6572194899245;
*8dab680f590bf416799da50b07c6;
*8da4655f990a2507784814d1c4ae;
^CSignal caught, exiting!
User cancel, exiting...
pi@raspberrypi:~ $
obj
2
Directly? No; it doesn’t do a networked feed (so you need socat, as you found) and it uses the AVR format (so you need to convert from AVR to Beast).
But there’s not really any point in using rtl_adsb over over decoders that use librtlsdr, it’s not much more than a “proof of concept” decoder.
@obj
Thanks Oliver for clarification.
