Can I change the port/path to use a single 1090 dump file?
#1
Hi, new to this setup stuff and have checked the posts for an answer but didnt find anythng, I am trying to use a single 1090dump file for feeding into FA and FR, apparently it can be done. I cannot see how I can change the port (and/or path) on the FA to 30002 so that it feeds from a single file. At the moment I have both FA and FR running but it does not look like the dongle will see both and will only accept feed into the FA file.
(If there is a quick and easy way to config the FR to read the FA dump then happy with that as an offering!)
I am currently running a Pi Zero with FA and FR with a single dongle.
Thanks in advance
#2
All the work has already been done by @jprochazka
Look at
You get the feeders of your choice and decent stats.
:slight_smile:
Edit. Joe’s site seems to be down at the moment.
#3
YES, there is a very easy way. Please see item (3) QUICK METHOD below.
The detailed answers are here:
(1) Flightradar24 Forum: How to Feed Data to Multiple Sites - A Brief Guide
(2) This Forum: Bake a Pi, Additional Feeders
Scroll down to "2) INSTALLATION OF FR24 DATA FEEDER:"
Further scroll down to “Post Install configuration/Re-configuration of FR24 feeder
(3) QUICK METHOD (if you don’t want to read above posts):
Type this address in your Browser
http://< IP of PI >:8754/settings.html
On the settings page opened, set the “Receiver” and “Host/IP” to any one of the following two:
Receiver: ModeS Beast(TCP)
Host/IP: 127.0.0.1:30005
OR
Receiver: AVR(TCP)
Host/IP: 127.0.0.1:30002
Hit “Save” button at bottom-right of page, then hit “Restart” button next to it.
Wait for some time, status page will appear. Initially it will show nothing working, but after a minute or two reload it and it will show everything is normal.
#4
Many thanks for the details Jon, just waiting on another pi to arrive and will try and see if I can get something to work. I see I have been sent another option so will try both when I get time.
#5
Thanks for the suggestion, I am waiting on another pi and will test to see what I can get working
