Buffer overflow on attemp to reconnect to adeprt server
Good day,
noted that since 20.11.2022 when connection to adept server is lost then after 6 reconnection attempts piaware is terminted with buffer overflow error.
Here is the last case from today:
2022-11-28 08:28:23Z 1082827 msgs recv’d from dump1090 (920 in last 5m); 1080945 msgs sent to FlightAware*
2022-11-28 08:30:02Z timed out waiting for alive message from FlightAware, reconnecting…*
2022-11-28 08:30:02Z multilateration data no longer required, disabling mlat client*
2022-11-28 08:30:03Z fa-mlat-client exited normally*
2022-11-28 08:30:03Z reconnecting in 4 seconds…*
2022-11-28 08:30:03Z mlat-client(16014): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data*
2022-11-28 08:30:03Z mlat-client(16014): Exiting on connection loss*
2022-11-28 08:30:07Z Connecting to FlightAware adept server at piaware.flightaware.com/1200*
2022-11-28 08:30:32Z Connection attempt with adept server at piaware.flightaware.com/1200 timed out*
2022-11-28 08:30:32Z reconnecting in 5 seconds…*
2022-11-28 08:30:37Z Connecting to FlightAware adept server at piaware.flightaware.com/1200*
2022-11-28 08:30:38Z Connection with adept server at piaware.flightaware.com/1200 established*
2022-11-28 08:30:52Z Connection attempt with adept server at piaware.flightaware.com/1200 timed out*
2022-11-28 08:30:52Z reconnecting in 4 seconds…*
2022-11-28 08:30:56Z Connecting to FlightAware adept server at 206.253.80.201/1200*
2022-11-28 08:31:11Z Connection attempt with adept server at 206.253.80.201/1200 timed out*
2022-11-28 08:31:11Z reconnecting in 5 seconds…*
2022-11-28 08:31:16Z Connecting to FlightAware adept server at 206.253.84.194/1200*
2022-11-28 08:31:20Z Connection to adept server at 206.253.84.194/1200 failed: host is unreachable*
2022-11-28 08:31:20Z reconnecting in 61 seconds…*
2022-11-28 08:32:21Z Connecting to FlightAware adept server at piaware.flightaware.com/1200*
2022-11-28 08:32:36Z Connection attempt with adept server at piaware.flightaware.com/1200 timed out*
2022-11-28 08:32:36Z reconnecting in 4 seconds…*
2022-11-28 08:32:40Z Connecting to FlightAware adept server at piaware.flightaware.com/1200*
buffer overflow detected : terminated**
In old forum discussion noted that there might be something related to tls bug and IPv6
In current config Pv6 is disabled.
tls version is 1.7.16
gnutls version is 3.6.14
piaware version is 6.1
Until 20.11.2022 after 888 days there was no such buffer overflow termination.
Also noted that not all reconnections exhibit this behavior… Here are all “connection lost” events with reconnections to adept server since 20.11 and only in 3 cases buffer overflow happens.
It may be assumed that some of “connection lost” are caused by local internet provider and others are from far end i.e adept server and just then something happens with buffer.
20.11.2022 2:25 utc *** buffer overflow detected ***: terminated
22.11.2022 21:04 utc *** buffer overflow detected ***: terminated
24.11.2022 8:42utc
25.11.2022 9:50utc
25.11.2022 17:47utc
27.11.2022 01:16utc
27.11.2022 10:54utc
27.11.2022 21:22utc
28.11.2022 8:28 utc *** buffer overflow detected ***: terminated
Any suggestion for troubleshooting are appreciated
This is usually caused by a tcl ipv6 problem: buffer overflow when IPv6 gets disabled · Issue #51 · flightaware/piaware · GitHub
As a workaround, remove the IPv6 entry for localhost in /etc/hosts.
This is causing the buffer overflow.
