Browse by aircraft type. Missing Airbus A380
When I do a browse by aircraft type and select A388, I’ve noticed in the last few weeks that flight DLH440 (Frankfort to Houston) is missing. But when I use the flight tracker it shows up. Could someone please correct this?
About what time were you looking at this? flightaware.com/live/aircrafttype/A388 only lists flights that are currently in the air, and right now it’s listing DLH440. It is a ways down the list though, since the list is sorted by departure time and DLH440 has been in the air for almost six hours.
No earlier than 10:00 a.m. CST. Most clear days I check around 11:00, because if it does fly over my home it would be around 11:30. So I check earlier to see the flight plan.
BTW, when I check for A388 flights, I use the map. That’s where it doesn’t show up. But when I search for the flight it does show up on the map. I like to see if any a380s are flying over the upper midwest.
I see now flight DLH440 is near the Cape Cod area.
This was today at 10:45 am. The picture doesn’t show Houston. It did a half-hour later though.
[http://picpaste.com/extpics/Houston_we_have_a_problem.PNG]()
I then search for the flight.
[http://picpaste.com/extpics/Luft440.PNG]()
But when I went back to browse by aircraft type I didn’t see DLH440 over Canada. Usually I would see over Canada but not in the last few weeks.
[http://picpaste.com/extpics/a_minute_later_not_shown.PNG]()
